Nova verzija Winlog32 4.5.01
Moderator: s52aa
OdgovorNapisal/-a S51AY » 08 Sep 2008, 12:35
Včeraj je izšla nova verzija 4.5.01. Novosti:
v4.5.01 released 07 September 2008
DXCluster:
Added right-click drop down menu to select:
From Callsign field
Copy to log
Look-up Callsign in Log
Look-Up country Look-up DXCC
Look-up Callsign in Callbook
Look-Up Callsign @ QRZ.COM
Look-Up Callsign @ IK3QAR
From Frequency Field:
Return Rig to Previous Frequency
From Remarks field:
Look Up IOTA Look-up IOTA in Log
Look-up Grid Locator
Look-up Grid locator in Log
From Spotter Field:
Look Up spotter in Log
Saves DXCluster column widths.
Callbook:
Refined behaviour in some functions
LoTW Manager
Added BPSK125 to Mode rationlising.
Added error checking on TQL file name/path
Rig Control:
Ten Tec, fixed European number translation problem when sending frequency from memory buttons.
Winkey:
Fixed Winkey 1 initialisation problem?
QSL designer:
Fixed funtion which adds comments from Remarks & User fields enclosed with [ ] to label
Bug fixes:
Fixed: Bug in QSLOUT field, when using Updated 'NET' (internet DXClusters) database.
Fixed: Bug in Callbook window, occasional crash when searching.
Includes latest Prefix Update
73 - G0CUZ
Pridružen: 01 Jan 2006, 11:01
Re: Nova verzija Winlog32 4.5.01
OdgovorNapisal/-a s57wos » 26 Sep 2008, 12:39
Zdravo ..
Program izgleda solidno. Imam pa problem, oz. nikjer ne vidim kam bi lahko vpisal grid-lokator?
Lp.
Srecko
S57WOS
s57wos
Prispevkov: 188
Pridružen: 20 Maj 2001, 01:00
Kraj: Maribor JN76UN
OdgovorNapisal/-a S51AY » 26 Sep 2008, 13:19
Da ga bo prepoznalo kot grid, ga moraš vpisati na začetku polja "Remarks". Bistveno je, da je na začetku tega polja, kot prvi tekst (prvi vnos). Lahko vnašaš kompletne, 6 karakterne gride, ali pa samo 4 karakterne. Statistiko gridov pa vidiš pod "Database - VHF LOCATOR - edit, po bandih, tudi KV.
Vrstni red ostalih stvari v tem polju ni pomemben. Da bo stvari upoštevalo v ustreznih bazah, moraš npr. za QSL managerja napisati QSL via CALL, za IOTO napišeš samo IOTA XX-XXX, za USA state CTY XX,....
Primer v Remarks polju npr. za FK8GX: RG28AA , Michel - Bourail , QSL via W3HNK , IOTA OC-032 itd. No ni čisto itd., omejen si s prostorom.
Za USER databaze pa preberi navodilo za to.
Prijetno zabavo !
Arpi-S51AY
Zadnjič spremenil S51AY, dne 26 Sep 2008, 14:34, skupaj popravljeno 1 krat.
OdgovorNapisal/-a S51AY » 26 Sep 2008, 14:04
Srečko, še ena sugestija pri vnosu. Da se ne bi jezili, koliko je tu treba "dotipkavati", lahko naredimo naslednje.
Pod "Options / Settings - Function Keys" lahko definiramo tekste, ki bodo "izleteli", ko pritisnemo eno od tipk F5-F8. Npr. pod F5 vpišeš "QSL via", pa ko si s kurzorjem v Remarks ali User polju, pri pritisku na F5, tja prilepi "QSL via". Ti pa moraš narediti le en presledek in vpisati znak managerja. Itd. za ostale stvari, ki jih najpogosteje rabiš. Pa spet ni čisto itd., ker lahko definiraš le 4 tipke (F5-F8) :D :D
73, Arpi-S51AY
Vrni se na HamSoft
