s57u napisal/-a:Danes je bila objavljena nova verzija Logger32 ver.3.9.
Release change notes for Ver 3.9.0 as of....... 8 Feb 08
Once again there have been changes to the menus. Existing language files will not work. Users will need to update their language DLL.
There have also been changes to the external interface and as a result current applications designed to work with this will probably not work at all. FreqManager and CheckCall are two such programs. Authors of these programs have been involved in the development of the new interface so they are well aware of the situation. They will issue upgraded software to match the new interface in their own time.
1) The focus of Logger32 ver 3.9 has been the coding of a revised external interface. Details are contained in the help file.
2) Fixed a bug associated with the Monitor Band Maps
3) The DX Activity Window is now sizeable.
4) As requested, see new menu item ... Right click on DX Spot Window. Click SETUP | HIGHLIGHT CALLSIGN CELL ONLY
[Help file change - GWA]
5) Corrected a bug which gave port error messages in the DVK.
6) Support now included for the Elecraft K2/K3. Modes supported are the same as Kenwood: LSB, USB, CW, AM, RTTY, CW-R, RTTY-R.
Adding the following (examples only) to the Logger32.INI will add filter selection commands when setting/changing the K2/K3 mode by CAT.
[Elecraft Filter n]
USB=XXpppppp;
LSB=XXpppppp;
CW=XXpppppp;
Where n is 1 or 2 (for radio 1 or 2), XX represents the command prefix letters and pppppp represents the command parameter
7) New feature added/supported when using the generic Kenwood - All radio control. Adding the following (examples only) to the Logger32.INI will add filter selection commands when setting/changing the Kenwood mode by CAT.
[Kenwood Filter n]
CW=XXpppppp;
USB=XXpppppp;
LSB=XXpppppp;
The Radio Modes supported by the generic Kenwood All selection are CW, RTTY, FSK, FSK-R, CW-R AM, FM, LSB and USB.
8.) ICOM USERS PLEASE NOTE; For consistency, the user input for Icom filter selection has been changed (both the Logger32.INI section and item names. An example of the new Loger32.INI format is:
[Icom Filter n] where n is 1 or 2 (for radio 1 or 2)
CW Normal=01
CW Narrow=02
