Pretvorba v .bin
Moderator: s52aa
Pretvorba v .bin
OdgovorNapisal/-a S51U » 11 Feb 2007, 21:53
Pozdravljeni !
Kako bi lahko pretvoril dnevnik, narejen v MMTTY ( lahko je adi, cabrilo ... ) v bin format, da bi ga lahko insertiral v CT ?
WPX sem namreč delal z MMTTY in sedaj bi moral na roke računati rezultat. Če bi ga lahko spravil v CT, mi to odpade.... Mogoče se da to narediti kako drugače..
Hvala za nasvete.
73 de Mario - S51U
S51U
Prispevkov: 371
Pridružen: 12 Jul 2006, 13:50
Kraj: JN75GX
OdgovorNapisal/-a s55oo » 11 Feb 2007, 22:22
Racunas samo zase, komisija itak prebere cabrilo in ti potem na osnovi tega naredi rezultat.
Ce ti to kaj pomaga...
73,
Goran ANDRIC, S55OO
s55oo
Prispevkov: 261
Pridružen: 02 Avg 2001, 02:00
Kraj: Domzale
OdgovorNapisal/-a S51U » 11 Feb 2007, 23:24
s55oo napisal/-a:Racunas samo zase, komisija itak prebere cabrilo in ti potem na osnovi tega naredi rezultat.
73,
Se pravi, da ne prijavljam nobenega rezultata, cool.
Hvala.
S51U
Prispevkov: 371
Kraj: JN75GX
OdgovorNapisal/-a s55oo » 11 Feb 2007, 23:31
Ko bos posiljal ti bo najbrz tudi SWrobot odgovoril, ce je ok ali ne, preveris pa lahko tudi pri managerju. Glej K9SZ.
# Electronic Submissions.
All electronic logs must be submitted in Cabrillo format via e-mail to:
E-mail:
wpxrtty@kkn.net
Receipt of all e-mailed logs will be confirmed via return e-mail.
1. In the "Subject" line of your e-mail message please include your callsign and the category you entered—i.e., SOABL, M2, MS, etc. Logs should be sent as an e-mail attachment, not in the text of the email, and the filename for the log should be yourcall.log.
2. Entries from Multi-Single, Multi-Two, and Multi-Multi stations must be merged into a single chronological log that clearly indicates which transmitter made each QSO (column 81 of Cabrillo QSO template for CQ contests). Multi-Single and Multi-Two should designate their transmitters as 0 and 1.
3. If the Cabrillo format is unavailable, contact the log checker, Joe Wittmer, K9SZ, at <k9sz@wittmer.us>.
# Disks and paper logs may be submitted via mail to:
Mailing address:
CQ RTTY WPX Contest
25 Newbridge Road
HICKSVILLE, NY 11801
USA
However, all logs containing more than 100 QSOs and which were generated using a computer program must be submitted via e-mail or on a 3.5 inch floppy disk.
Log and summary sheets are available for download on the CQ website,
<www.cq-amateur-radio.com>, or with SASE from CQ at the address listed above.
# Questions pertaining to the CQ RTTY WPX Contest may be sent to the Contest Director, Glenn Vinson, W6OTC, 488 Locust Street #401, San Francisco, CA 94118, USA; e-mail <w6otc@garlic.com>.
73,
Goran ANDRIC, S55OO
s55oo
Prispevkov: 261
Kraj: Domzale
OdgovorNapisal/-a S51U » 13 Feb 2007, 07:47
Ja, danes bom poslal, hvala. Pri CTju je to lepše, da imaš tudi tezultat takoj - edino to me je motilo.
Ostalo mi je nekako jasno, hi...
73 !
S51U
Prispevkov: 371
Kraj: JN75GX
OdgovorNapisal/-a S50DX » 13 Feb 2007, 08:30
Hoj...
En komentar, sicer ne bo pomagal nič, mogoče pa za drugič... :wink:
Tekmovanja bi lahko delal tudi z MixW ali pa z N1MM, kjer vidiš rezultat takoj.
In tudi izvozil v cabrillo, adi...
Lpa.- 8)
Prispevkov: 468
Pridružen: 23 Apr 2003, 14:46
Vrni se na HamSoft
