N1MM+POMOČ
OdgovorObjavljeno: 26 Dec 2016, 12:22
Napisal/-a s57ay
Kako nastaviti generiranje raporta za RAEM kontest.
Za moj primer naj bi izgledal takole:
Serijska št. zveze in geografske koordinate
TT1 46N 14O za prvo zvezo. ali pa
001 46N ...... itd.
Raje TT1 kot 001
Vprašanje za poznavalca verjetno lahko rešljivo, zame problem.
Hvala za pomoč
73 Ted
Re: N1MM+POMOČ
OdgovorObjavljeno: 26 Dec 2016, 12:46
Napisal/-a s51fb
Ted pozdravljen
Najenostavneje je, da se prepustiš N1MM+ programu saj je vsaj meni program sam ponudil pravo obliko raporta. Seveda sem ob tem popravil podatke o lokaciji z dejanskimi koordinatami.
Drugače pa je oblika raporta: # 46N14O (za Ljubljano).
Lp
Miha, S51FB
p.s.:
- za vsak slučaj, RAEM 2016 tekmovanje je vsaj po podatkih s te spletne strani http://raem.srr.ru/en/2016-rules/ preteklost
Re: N1MM+POMOČ
OdgovorObjavljeno: 26 Dec 2016, 15:17
Napisal/-a s55o
Če odstraniš presledke v raportih, bo vse v redu. Enaki problem imajo tudi drugi, ker imajo presledke v raportih.
http://n1mm.hamdocs.com/tiki-index.php? ... CW_contest
Window: Select Log type
Log Type: RAEM
Mode Category: CW (it is a CW only contest)
Sent Exchange: 001 & Coordinates Example: 001 53N6O
The own coordinates is the second token in Sent Exchange without spaces (one 'word')
Coordinate rules: These rules apply for the 'Sent Exchange' and also when entering a coordinate in the Entry Window.
Own coordinates: Second token in Sent Exchange without spaces (one 'word')
First part is the Longitude with at the end N or S Example: 53N
Second part is the Latitude with at the end W or O (not E) Example: 6O
As a total this makes: 53N6O
Log and rescore: To generate the log use the Generic log file and the Score summary. Always rescore and check the log. If a qso has 1 point then the Received exchange is not correct. If there are QSOs who have gotten 2 points then your Sent Exchange is not correct. Update your Sent Exchange in the contest setup and rescore. Check again.
Call History: The call history can be used but... the coordinates have to be entered in the Name field of the Call History table. This is the only field which is capable of handling all different coordinates 1N2W but also 67N169O
Re: N1MM+POMOČ
OdgovorObjavljeno: 27 Dec 2016, 09:16
Napisal/-a s57ay
Hvala obema za pomoč.
To sem uredil razen tega, da mi n1mm ne generira raport 001 .....(kordinate)
ampak samo 1 .....
Tudi v drugih kontestih pošiljam raport za prvo zvezo 5nn1. ne spominjam se kdaj sem tako nastavil.
Želel bi 5NNTT1 in 5NNTT2 .....
Lep pozdrav vsem.
HNY 2017 Ted
Re: N1MM+POMOČ
OdgovorObjavljeno: 27 Dec 2016, 11:13
Napisal/-a s50xx
Config > Configure Ports, Mode Control, Audio, Other...
zavihek Function Keys
prva opcija (kljukica) Send leading zeros in serial numbers
Kristjan, S50XX
Re: N1MM+POMOČ
OdgovorObjavljeno: 27 Dec 2016, 13:14
Napisal/-a s57ay
HVALA.
Deluje vse OK.
73 Ted
