MixW
Moderator: s52aa
MixW
OdgovorNapisal/-a s56wrt » 30 Avg 2011, 14:19
nikakor mi ne uspe izvozit iz MixW programa *.cbr zapisa. Pred časom mi je že uspelo pa sem pozabil kako ? :cry:
Prosim za pomoč.
73 de S56WRT - Robert
s56wrt
Prispevkov: 59
Pridružen: 14 Nov 2004, 19:54
Re: MixW
OdgovorNapisal/-a s55o » 30 Avg 2011, 14:31
MixW Notes
(Thanks to Rich, VE3KI (ex-VE3IAY) for providing these notes. Any errors are the responsibility of the editor, W0YK)
In order to create a proper Cabrillo format log, MixW must be properly configured before stations are worked and logged. Otherwise, extensive text editing will be required to transform the Cabrillo file that MixW produces after the contest. Here are the steps for using MixW in CQ WPX RTTY and creating a correct Cabrillo 2.0 format file:
Set up for the contest using MixW's "View -> Contest mode" or "Logging -> Contest mode" menu item. Create a new contest setup using the "Add new" button. Be sure to fill in the correct UTC start and end dates and times for this year's running of the contest in the Contest settings dialog. Check the "AutoInc" check box.
Log the received exchange for each contact into the following two fields:
RST_recvd
Exch_recvd (serial number)
After the contest, invoke the Cabrillo export function in MixW to create your Cabrillo file for submission as described above in Electronic Logs.
Select the "Simple (RST & exch number)" Cabrillo format.
Open up the Cabrillo file in a text editor (Notepad, Wordpad, MS Word, etc.) and verify that it conforms to the Cabrillo specification above in Editing the Cabrillo File, particularly the QSO data format. Both the sent and received exchange must have two elements: RST and serial number). Note that some of the Cabrillo header lines are different between version 2.0 created by MixW and version 3.0 shown above. This is OK because after emailing your log (see next step 6.), the server will convert those lines to version 3.0 which you will see in the reply email.
After submitting your Cabrillo file to rtty@cqwpx.com, you will receive a reply email message saying that your log format is OK, or listing the specific problems that you must correct and then re-submit to rtty@cqwpx.com.
Hvala za zveze lp! Je pa komplicirano, zato imam rad n1mm in mmtty :)
Prispevkov: 2525
Re: MixW
OdgovorNapisal/-a S53F » 30 Avg 2011, 22:44
Živjo!
Za izvoz cbr datoteke iz mixw programa je naslednji postopek:
Pritisni alt+r, odpre se ti okno search in logfile, izberi whole log, odpre se ti log in na log klikni z desno miškino tipko, izberi vse, da ti označi cel log in klikni na spodnji meni to cabrilo. Isti postopek je za izvoz adi datoteke.
73 de Vinko, S53F
S53F
Prispevkov: 117
Pridružen: 13 Nov 2005, 18:48
Re: MixW
OdgovorNapisal/-a s56wrt » 31 Avg 2011, 07:26
Hvala obema za pomoč. Sem z converterjem rešil zadevo ker mi po nobenem postopku ni uspelo.
@Vinko po tvojem postopku mi ni delalo *.adi ni problem *.cbr pa nikakor. Veliko uporabljam ta program ampak za izvoz pa samo v *.adi datoteko.
Rešeno hvala
s56wrt
Prispevkov: 59
Re: MixW
OdgovorNapisal/-a S50DX » 31 Avg 2011, 08:49
Pa imaš naložene vse DLLje tudi za tekmovanja?
Sam nisem imel nikoli težav pri izvozu CBR. Delal pa tako kot je opisal Vinko.
PODXS 070 # 173 - EPC # 0066
S50DX
Prispevkov: 464
Pridružen: 23 Apr 2003, 13:46
Kraj: Prevalje
Re: MixW
OdgovorNapisal/-a S51AY » 31 Avg 2011, 10:37
Alo !
Klikneš na tista očala, pa Whole log, da se ti odpre celoten log. Označiš zveze, ki bi jih rad izvozil, potem pa tipko to Cabrillo. Kot je napisal Vinko. To je vedno delalo...
Pridružen: 01 Jan 2006, 11:01
Re: MixW
OdgovorNapisal/-a s56wrt » 31 Avg 2011, 15:41
S51AY napisal/-a:Alo !
Ja Arpi tako sem tudi naredil. Mogoče pa res nimam vseh potrebnih *.dll datotek naloženih.
s56wrt
Prispevkov: 59
Re: MixW
OdgovorNapisal/-a S50DX » 31 Avg 2011, 19:20
DLLji za conteste so sicer za pravilno točkovanje med tekmovanjem. Ne vem več, ali so potrebni tudi za CBR.
Je že precej časa nazaj, ko sem na zadnje delal tekmovanja... :(
S50DX
Prispevkov: 464
Kraj: Prevalje
Re: MixW
OdgovorNapisal/-a S51AY » 31 Avg 2011, 19:31
Hja, ko izvažaš v Cabrillo, moraš navesti tudi contest. Dll-je za konteste se lahko "skine" tukaj : http://www.mixw.net/index.php?j=contests
Posnamejo se v MixW\Plugins direktorij, pa stvar mora delati...
P.S.
Upam, da ni potrebno napisati, da moraš dll-je prej unzipati...
Re: MixW
OdgovorNapisal/-a s56wrt » 31 Avg 2011, 19:51
S51AY napisal/-a:
P.S.
:D
Ja tudi contest je treba nastavt ampak SCC RTTY, tega nikjer ne dobim !? To me še najbolj moti :cry:
s56wrt
Prispevkov: 59
Re: MixW
OdgovorNapisal/-a s57ad » 01 Sep 2011, 11:53
s56wrt napisal/-a:
S51AY napisal/-a:
P.S.
:D
Kdo pravi, da ga ni?! Jaz sem ga takoj našel (SCC RTTY Championship)!
s57ad
Prispevkov: 415
Pridružen: 17 Apr 2004, 17:40
Re: MixW
OdgovorNapisal/-a S51AY » 01 Sep 2011, 14:22
s57ad napisal/-a:
s56wrt napisal/-a:
S51AY napisal/-a:
P.S.
:D
Tebi je lahko Mirko, ko takoj iz prve vse unzipaš... :D :D :D
*** StatsSccRtty.zip ***
Zadnjič spremenil S51AY, dne 01 Sep 2011, 14:26, skupaj popravljeno 2 krat.
Re: MixW
OdgovorNapisal/-a s56wrt » 01 Sep 2011, 14:24
s57ad napisal/-a:
s56wrt napisal/-a:
S51AY napisal/-a:
P.S.
:D
Aha malo nerodno sem napisal. V programu sem mislil. Na strani sem to dobil brez problema, vse to sem že pred tem naredil predno sem začel tukaj na forumu spraševat. Ko hočeš izvozit (v programu) v cabrillo format seveda moraš izbrat tudi kontest ampak notri so (arrl, bartg,...) SCC RTTY pa manjka.
Sedaj sem rešil vse z converterjem kateri izgleda popolnoma enako kot kot bi iz programa hotel izvozit v določen format, vse napišeš in klikneš, dela ufb.
s56wrt
Prispevkov: 59
Vrni se na HamSoft
