N1MM+ in RTTY nastavitve MMTTY in 2TONE
Moderator: s52aa
Re: N1MM+ in RTTY nastavitve MMTTY in 2TONE
OdgovorNapisal/-a s54mtb » 27 Avg 2015, 08:48
Priprava na vikend? 8)
Pridružen: 01 Apr 2014, 18:25
OdgovorNapisal/-a s55o » 27 Avg 2015, 20:45
Jaz jih že dobro poznam, mogoče pa še koga opogumim, pa da bo vse na enem mestu!
Malo je RTTY tekmovanj, kjer lahko delaš 24 ur z rate 50..
Se slišimo v tekmovanju! (s51a)
Prispevkov: 2595
OdgovorNapisal/-a s55o » 26 Avg 2016, 07:28
Za začetnike z n1mm dodajam naslednje tutoriale glede nastavitev n1mm in mmtty
http://www.rttycontesting.com/tutorials/n1mm/plus/
http://n1mm.hamdocs.com/tiki-index.php? ... K+Contests
http://aa5au.com/GettingStartedOnRtty.pdf
http://contestuniversity.com/attachment ... _2013e.pdf
Nekaj dobrih zadev, ki jih pozabljamo pred contesti pogledat še 1x:
http://n1mmplus.hamdocs.com/tiki-index. ... ssignments
*Edit a QSO without a mouse*: Ctrl+Q/A = Quick edit previous or next
call. Use Ctrl+Q to go backwards in the log, Ctrl+A to go forwards.
Change what needs to be changed and press enter to terminate Quick Edit.
*Unwipe a QSO*: Press Alt+W a second time. It's a toggle.
*Edit the function keys*: Alt+K (or right-click on the buttons)
*Delete the spotted contact in the **call frame*: Alt+D. This doesn't
blacklist the spot, but it is quick to do.
*Toggle in and out of Enter Sends Message Mode (ESM)*: Ctrl+M. If you
aren't using ESM for CW, you should be:
http://n1mmplus.hamdocs.com/tiki-index. ... ds+Message
*Use the mouse wheel*:
1. With the cursor over a bandmap, it zooms that bandmap. Try it.
2. With the cursor over the Telnet window it scrolls that window.
3. With the cursor over the Entry window it changes frequency:
a. By 20 Hz per click
b. By 1 kHz per click with Alt pressed
c. By 10 kHz per click with Ctrl pressed
d. By 100 kHz per click with Alt+Ctrl pressed
*Type a frequency or mode into the callsign textbox*: e.g.
1. 21044
2. 48
3. +5, -2
4. Ctrl with enter to set split freq as in 1-3 above. 48 Ctrl+Enter
**Jump from spot to spot by beam heading*:
1. In the Available window, click on the beam heading to sort by heading.
2. Use Alt+A & Alt+Shift+A to move up and down the list of spots in beam
heading order. This works for other sort orders as well.
*Change font size by window*: The main font in most windows size can be
adjusted by using the little up/down "font sizer" control in each of the
windows that this works in. Try it!
Try reviewing the Key Assignments page before your next contest. Pick
out a couple of features you did not know about to expoit.
Prispevkov: 2595
OdgovorNapisal/-a s55o » 26 Avg 2016, 09:29
Še posnetki za tiste, ki jim je lažje to početi po videu:
http://n1mm.hamdocs.com/tiki-index.php? ... nal+Videos
Prispevkov: 2595
Vrni se na HamSoft
