Nova verzija Logger 3.12
Moderator: s52aa
OdgovorNapisal/-a s57u » 08 Jul 2008, 14:18
Danes je bila objavljena nova verzija Logger32 ver. 3.12.
Priporočam, da sproti posodabljate verzije, sicer se lahko zgodijo razne neprijetnosti pri skokih preko več verzij. Na WEB stran bo v kratkem naložen prevod v slovenščino, ki velja samo za trenutno verzijo 3.12!!!!
Še pregled novosti za ver. 3.12:
Release change notes for Ver 3.12.0 as of....... 5 July 08
NOTES:
As there have been a number of changes to the menus, current Language DLLs
will no longer work.
You must recalc stats immediately after loading this new version.
1) The "V" enumeration has been extended to the IOTA search/additional
information window.
2) Corrected a minor problem with the use of macros in the MMVari window
3) Corrected a bug that caused an incorrect flagging of eQSL and LOTW QSLs
when using the quick QSL window
4) As the DXCC totals are presented regardless of the number of bands
verified/confirmed/worked,
the verified DXCC totals are now presented in the same way. Also there have
been changes to
DXCC and DXCC Challenge awards to better show QSL received V status
including summary lines
showing Vs count.
5) The user can now select which award is being monitored by the "V" flag
and have the stats tables respond accordingly.
See the new menu item introduced into the IOTA, DXCC and Challenge awards
windows and note that all the windows
for one award are linked. Switching on the facility in one window will do
the same for all other related windows.
The DXCC and Challenge windows can operate at the same time and the turning
of these ON will turn OFF those for the IOTA award..
6) The user may now select the "donotdelete.xls" form to be used with the
awards tables. See the new menu item following a right click on the
appropriate award table. A different template can be selected for each of
the main (Continents, CQ Zones,
DXCC, DXCC Challenge, IOTA) Awards. The default is still doNotDelete.xls
7) A new option has been added to the LotW sync routines. The user may now
check the option to flag LOTW QSL_Rcvd fields as "Verified"
8) The ADD form should now remember the last used Band/Mode.
9) Bug correction to the non global setting for the ALT_A function (rotate
antenna to long path)
10) A typo connected with the SO2R AFC on/off in the MMVari section of the
INI file has been corrected.
11) Changes to DX Spot Window setup of alert colo(u)rs and audio alerts.
See menu changes to IOTA
Spot Map Window (additional colour selection for Verified IOTAs).
12) Logger32 now has a single flag for selecting which award (if any) the
QSO verified capability is applied.
This single flag is accessible from (currently) three places ...
a) The SETTINGS Menu on the DXCC Award Window,
b) the SETTINGS Menu on the IOTA Award Menu, and now
c) the Settings Menu on the Window used to setup DX Spot colours -
SETUP|APPEARANCE|DX SPOT COLOURS
A new section in the help file called the "V" enumeration has been added.
13) Audible and visual notification of DXCC/Challenge or IOTA verifications
added to the dxspot table and the Dx spot map
14) The stats files now include a new set called VerifiedDB32.xxx V lookup
now uses a database index, and should
now be mercuric in operation. You must recalc stats immediately after
loading this version.
CUL
Polde, S57U
s57u
Prispevkov: 125
Pridružen: 13 Feb 2006, 23:08
Vrni se na HamSoft
