Žica za sidranje stolpa
OdgovorNapisal/-a S50B » 08 Sep 2012, 11:42
Zdravo!
Zanima me, kje v SVN se dobijo zadeve za sidrat stolp? Iščem namreč žico ala bayco, ki je iz plastike. Baje naj bi podobno zadevo Finci OH8X kupavali v Škofji Loki! Ali ima kdo kako informacijo?
73 de Borut S50B
ex. S57AP, YT3TT
S50B
Prispevkov: 58
Pridružen: 12 Jul 2003, 20:00
Kraj: Budanje
Re: Žica za sidranje stolpa
OdgovorNapisal/-a s53nw » 08 Sep 2012, 15:35
Za Skofjo loko ne vem.
A to je poliamidna ali kevlar vlakna spletena v vrvico?
No.... podobna tema je bila ze v teku dobro leto nazaj viewtopic.php?f=17&t=11409
LP HErman / s53nw
ex. s57onw
+ Picasa Public Gallery +
Once Primorec, always Primorec! 8-)
s53nw
Prispevkov: 26
Pridružen: 31 Okt 2002, 12:39
OdgovorNapisal/-a S55SR » 09 Sep 2012, 02:17
S50B napisal/-a:Zdravo!
73 de Borut S50B
Pogley v kakšni navtični trgovini za "špago" DYNEEMA. Jo uporabljajo za jadra in jambore.
http://www.youtube.com/watch?v=GDJ3QjvRZT0
http://www.dyneema.com/emea/
ISF (imejte se fantastično)
Samo
S55SR
Prispevkov: 421
Pridružen: 28 Nov 2007, 18:11
Kraj: Koper - Capodistria
OdgovorNapisal/-a S51TK » 01 Okt 2012, 20:25
S51TK
Prispevkov: 83
Pridružen: 20 Apr 2003, 19:18
Kraj: Galicija p. Žalcu
OdgovorNapisal/-a S54Z » 02 Okt 2012, 22:10
Nylon Monofil guy wire
http://www.wimo.com/cgi-bin/verteiler.p ... nas_e.html
WiMO monofil vrvica:
Nylon Monofil is a new type of guy wire for antennas and masts. Monofil is not braided buit one solid wire of nylon, extremely solid, extremely low stretch, breaking load of the 5mm wire is 700kg! But still lightweight and weatherproof and due to the white color quite unobtrusive. For even higher breaking loads use several wires in parallel. Can be fitted with the usual mounting hardware.
The 2mm version can be used to brace antennas etc.
Technical Data 5mm Monofil (23101.x):
Material: 6 SNIA Nylon
Specific weight: 1.14 g/cm3
Specific breaking load: 35-40 kg/mm2
Breaking stretch: 15-20%
Diameter: 2 mm or 5 mm
Breaking load: 120 kg (2mmØ), 700 kg (5mmØ)
Nabavil sem kolut 500m v trgovini Jager (vinogradniška žica). Vrvica je izdelana v Bayeryu ima dvajset let garancije na obstojnost,
je ovalnega ploščatega preseka, ima zrcalno gladko površino, poskusil sem jo spajat s spajkalnikom vendar brez uspeha.
S54Z
Prispevkov: 131
Pridružen: 01 Sep 2004, 22:03
OdgovorNapisal/-a s55m » 03 Okt 2012, 22:48
OdgovorNapisal/-a S50B » 04 Okt 2012, 18:23
Hvala vsem za INFO. Bom pogledal naokoli!
73 Borut
ex. S57AP, YT3TT
S50B
Prispevkov: 58
Kraj: Budanje
OdgovorNapisal/-a S52OR » 19 Apr 2013, 09:08
Ima mogoče kdo viška 30m vinogradniške "žice" KORDON?
Proti plačilu seveda!
Tnx
73 Rado
S52OR
Prispevkov: 6
Pridružen: 19 Maj 2001, 02:00
Kraj: JN76HE
