Nova postaja s TNC za APRS?
Moderatorji: s56g, S57BBA
OdgovorNapisal/-a S56CT » 19 Mar 2007, 09:24
Američani že nekaj razpravljajo, pa tudi na rigpix so se pojavile fotke nove Kenwood mobilne postaje, ki naj bi nasledila TM-D700 in omogočala APRS oz. packet delo z serijsko vgrajenim TNC.
https://gullfoss2.fcc.gov/prod/oet/cf/e ... 50&fcc_id=
http://www.rigpix.com/kenwood/tmd701a.htm
Sedaj tudi uradna novica -TMV71E
OdgovorNapisal/-a S58T » 23 Apr 2007, 11:30
Res prihaja nova Kenwood mobilna radijska postaja, EU oznaka je TM-V71E.
Pri distributerju za Slovenijo, EN Miro Čadež s.p., bo na razpolago za ogled in preizkus v začetku junija.
Slika je na www.elnaprave.com
Miro S58T
Tehnični podatki:
TM-V71E VHF/UHF Dual Band FM Mobile Transceiver
Production May 2007
Introduction Dayton Hamvention (USA) … May 18-20
Ham Radio (Germany) … June 22-24
Ham Fair (Japan) … August 25-26
1. MAIN FEATURES
High RF Power Output (50W)
The TM-V71E provides an impressive 50 watts of RF power on both VHF & UHF, with a choice of High/Mid/Low settings.
Dual Receive on Same Band (VxV, UxU, VxU)
In addition to simultaneous receive on VHF and UHF bands, the TM-V71E can receive two frequencies on the same band (VxV, UxU).
Green & Amber Colour Display
To maximize visibility, the backlight colour of the large LCD display can be switched between green and amber.
Detachable Front Panel
For greater installation convenience the front panel of TM-V71E can be mounted separately, using the optional DFK-3D.
Invertible Front Panel
The front panel can be inverted, so that the transceiver body can be mounted with its internal loudspeaker in the optimum position.
Programmable Memory
For extra versatility, the TM-V71E has a programmable memory that can store five entire operating profiles, ready for instant recall at the push of a button. Each profile includes such settings as display mode, frequency range and memory mode.
1,000 Memory Channels
There are 1,000 split memory channels for storing essential data, such as transmit and receive frequencies, frequency step and tone frequency. Each channel can be identified with a 6-digit alphanumeric memory name. The memory data can be edited and stored on a PC, using the optional PG-5G interface cable and MCP-2A memory control software.
Multiple Scan
As well as VFO scan, programmable scan, MHz scan, memory scan and call scan, the TM-V71E offers memory bank scan. The 1,000 channels can be grouped into 10 banks for selective scanning. Scan resume (time-operated, carrier-operated and seek), memory channel lockout, tone scan, CTCSS scan and DCS scan functions are built-in.
Built-in CTCSS/DCS
The TM-V71E is equipped with analogue CTCSS (42 subtone frequencies) and digital DCS (104 codes) in addition to UK 1750Hz access tone.
EchoLink® Memory
Up to 10 EchoLink® memory stations can be stored using call signs (max. 8 alphanumeric characters). You can easily access an Echolink node terminal without having to use a call sign.
EchoLink® NODE TERMINAL Operation
When the TM-V71E is connected to a PC (with the necessary software installed) usinig the optional PG-5H, it can operate as a node terminal for Echolink® access.
(Note)
* Echolink® is a registerted trade mark of Synergenics LLC
* Echolink® official WEB site: http://www.echolink.org
Other Features
 Menu System
 Wide Band Reception : 118-524MHz & 800-1300MHz as standard
 Separate VOL/SQL for A and B Bands
 6-Pin Mini-DIN connector for External TNC
 8-Pin Mini-DIN connector for PC connection
 Programmable Function Keys
 Band Mask (Mask unused band)
 Call Channel
 S-meter Squelch & Hysteresis Timer
 Monitor Function
 Audio Mute & Hang-up Timer
 Automatic Power Off (up to 3-hours)
 MHz Mode
 Selectable Frequency Step
 Shift Function
 Repeater Offset (selectable)
 Automatic Repeater Offset (On/Off, VHF only)
 Reverse Function
 DTMF Memory (10 channels, 16 digits)
 Time-Out Timer
 Key Lock
 Power-on Password Protection
 Memory Shift
 Programmable VFO
 Beep On/Off, Volume Control
 Microphone program Function
 Channel Display Mode
 Power-On Message
 LCD Brightness Control, Automatic Dimmer
 Switch to External Speaker
 Reset (VFO, PART, PM, FULL)
 Cross Band Repeater Function (Dealer Modification)
 DTMF Remote Control (available in Cross Band Repeater mode)
2. OPTIONAL ACCESSORIES
 DFK-3D Quick-Release Detachable Front Panel Kit.
 MC-59 16-Key Hand Microphone
 MC-60A Desktop Microphone
 MJ-88 Microphone Plug Adapter
 PG-2N DC power Cable
 PG-3B DC Line Noise Filter
 PG-5A Data Cable
 PG-5F Extension Cable Kit (4m)
 PG-5G Programmable Interface Cable
 PG-5H PC Interface Cable
 PS-33 Power Supply (20.5A)
 PS-53 Heavy Duty Power Supply (22.5A)
 SP-50B External Speaker
2. SUPPLIED ACCESSORIES
 16-Key Hand Microphone (MC-59)
 Mounting Bracket
 DC-Cable
 Screw set & Fuses
 Users Manual
3. SPECIFICATIONS
General TM-V71E
Frequency Range Band A & B
Band A
Band B TX : 144-146 MHz, 430-440 MHz
RX : 118-524MHz
RX : 136-524MHz, 800-1300MHz
Mode F2D, F3E
Operating Temperature Range -20℃ to +60℃
Frequency Stability Within ±5ppm (-10°~ +50°C)
Antenna Impedance 50 ohm
Power Requirement DC13.8V ±15% (minus)
Current Drain Hi : 50W Less than 13.0A (VHF)
Less than 13.0A (UHF)
(transmit) Mid : 10W Less than 5.5A (VHF)
Less than 6.5A (UHF)
Low : 5W Less than 4.0A (VHF)
Less than 5.0A (UHF)
Dimensions (W x D x H)
Projections not included Panel : 140 x 38.2 x 43 mm
Body : 140 x 180.7 x 43 mm
Weight (net) 1.5 kg
Transmitter
RF Output Power Hi 50W
Mid Approx. 10W
Low Approx. 5W
Modulation Reactance modulation
Maximum Frequency Deviation Within ±5kHz
Spurious Radiation Less than -60dB
Modulation Distortion (300Hz ~ 3kHz) Less than 3%
Microphone Impedance 600 ohm
Receiver
Circuitry Double Super Heterodyne
Intermediate Frequency
1st IF (A Band/B Band)
2nd IF (A Band/B Band)
45.05MHz / 49.95MHz
455kHz / 450kHz
Sensitivity (VHF / UHF) Less than 0.16μV
Squelch Sensitivity Less than 0.1μV
Selectivity -6 dB
-50 dB More than 11kHz
Less than 30kHz
Kenwood follows a policy of continuous advancement in development.
For this reasons, specifications may be changed without notice.
S58T
Prispevkov: 256
Pridružen: 15 Apr 2007, 10:38
Kraj: Ljubljana Črnuče
OdgovorNapisal/-a s56oa » 24 Apr 2007, 21:07
Jaz sem pa bil že v strahu, da bo Kenwood povsem opustil HAM radio program. :oops:
Ogo
Member of S59DGO
http://www.s59dgo.org
Pridružen: 23 Maj 2001, 02:00
Kenwood
OdgovorNapisal/-a S58T » 01 Maj 2007, 20:21
Pri Kenwoodu sta najavljeni še dve novi Ham postaji, tako da nekaj se vseeno premika.
Miro S58T
S58T
Prispevkov: 256
OdgovorNapisal/-a s56oa » 01 Maj 2007, 21:16
Upamo, da dočakamo kako modernejšo nadomestitev za modela TH-D7 in TM-D700. :wink:
No, saj meni je tudi Icom všeč z novim modelom IC-2820, samo kaj ko lapa neke svoje digitalne standarde in zadeva ni uporabna za APRS. :(
http://www.icomamerica.com/products/amateur/2820h/
Je pa očitno prvi komercialni HAM radio RTX z 2 way diversity sprejemnikom. Kul za radioamaterje, ki hočejo zavoljo dodatnih decibelov na sprejemu, imet dve veliki anteni na svojem avtomobilu, da bo folk še bolj čudno gledal za njimi. Kot da že z eno veliko anteno na strehi nismo čudaki. Če mi to reče folk iz Nokia Siemens Networks, ki delajo bazne postaje in drugo VF tehniko, potem njihov komentar pove vse, hi. :lol:
73 de S56OA - Ognjen
Member of S59DGO
Re: Sedaj tudi uradna novica -TMV71E
OdgovorNapisal/-a s57vt » 02 Maj 2007, 21:32
S58T napisal/-a:Res prihaja nova Kenwood mobilna radijska postaja, EU oznaka je TM-V71E.
Koliko € bo pa predvidoma treba odsteti zanjo? :-?
VY 73, GL ES MNI DX! :)
Na bandih od 12. XII. 2006
Icom ID-52E
Yaesu FT-60E × 2
Retevis RT3S DMR
Quansheng UV-K5(8)
Baofeng UV-5R
s57vt
Prispevkov: 128
Pridružen: 19 Avg 2005, 11:49
Nova Kenwood mobilna duoband radijska postaja TM-V71E
OdgovorNapisal/-a S58T » 11 Jun 2007, 12:52
Kot sem obljubil,
TM-V71E, eno od treh Kenwood novosti, si lahko ogledate na mojem naslovu.
Miro S58T
s58t@qsl.net
041 569 207
Dodano 12.06: 360 Eur z DDV.
S58T
Zadnjič spremenil S58T, dne 12 Jun 2007, 07:38, skupaj popravljeno 1 krat.
S58T
Prispevkov: 256
OdgovorNapisal/-a s57vt » 11 Jun 2007, 14:45
Pa cena? :wink:
Icom ID-52E
Yaesu FT-60E × 2
Retevis RT3S DMR
Quansheng UV-K5(8)
Baofeng UV-5R
s57vt
Prispevkov: 128
KENWOOD TM-710E
OdgovorNapisal/-a S58T » 31 Jul 2007, 11:52
TM-D710E, nov Kenwoodov proizvod, zamenjava za TM-D700,
bom imel, kot kaže med prvimi na zalogi. Oktobra bo zaloga normalna, prve pa dobim že v septembru.
Poln opis z cenami bo na www.elnaprave.com takoj po dopustu.
Ker je novica sveža, besedila nisem prevedel.
Miro S58T
31st July 2007
We are pleased to send you preliminary information on our new VHF/UHF Dual Band Mobile Transceiver, the TM-D710E.
TM-D710E VHF/UHF Dual Band FM Mobile Transceiver
1. MAIN FEATURES
Built-In TNC
It has a built-in 1200/9600 bps TNC. With a portable computer, this allows you to enjoy Packet operation easily and it also enables you to enjoy the APRS®, and EchoLink® operation modes.
Full Dot LCD & Smart menu
The radio has a large full dot multi-functional LCD display (235x65 dots). It enables you to see the display easily, and you can operate the radio via its smart menu system which you can operate instinctively.
Over 60 APRS® menus
Various new APRS features are available. The predessor model, the TM-D700E, had 26 menus but the new TM-D710E has over 60 menus for greater APRS enjoyment.
The TM-D710E provides an impressive 50 watts of RF power on both VHF & UHF bands, with a choice of High/Mid/Low settings.
In addition to simultaneous receive on both VHF and UHF bands, the TM-D710E can receive two frequencies on the same band (V x V or U x U).
Programmable Memory
For extra versatility, the TM-D710E has a programmable memory function that can store five entire operating profiles, ready for instant recall at the push of a button. Each profile includes such settings as display mode, frequency range and memory mode.
Multiple Scan
As well as VFO scan, programmable scan, MHz scan, memory scan and call scan, the TM-D710E offers memory bank scan. The 1,000 channels can be grouped into 10 banks for selective scanning. Scan resume (time-operated, carrier-operated and seek), memory channel lockout, tone scan, CTCSS scan and DCS scan functions are built-in.
Built-in CTCSS/DCS
The TM-D710E is equipped with analogue CTCSS (42 subtone frequencies) and digital DCS (104 codes).
ECHOLINK® Memory
ECHOLINK® NODE TERMINAL Operation
When the TM-D710E is connected to a PC (with the necessary software installed) usinig the optional PG-5H, it can operate as a node terminal for Echolink® access.
(Note)
* APRS is a registered trademark Bob Bruninga, WB4APR
Other Features
 APRS features
 Decay Algorithm
 Proportional Pathing
 New-N Paradigm
 State/Section/Region Path
 Special Call Alert
 User Phrases
 QSY Function
 Visible Message Notifications
 Menu System
 GPS connector for NMEA 0183 format
 Call Channel
 Monitor Function
 MHz Mode
 Shift Function
 Reverse Function
 Time-Out Timer
 Key Lock
 Memory Shift
 Programmable VFO
 Power-On Message
 PG-5A Data Cable
 PG-5H PC Interface Cable Kit
 Mounting Bracket
 Mobile Angle, Panel Bracket (for Mobile Use), Panel Stand (for Fixed Base Station use)
 DC-Cable
 Screw set & Fuses
 Panel Separate Cable(8Pin Modular <->8Pin Modular 4m length)
 GPS Cable(Φ2.5mm Stereo Plug 2m length)
 Instruction Manual (Basic Operation)
 In-Depth Operation Manual (CD-ROM)
3. SPECIFICATIONS
General TM-D710E
Band A
RX : 118-524MHz
Mode F1D, F2D, F3E
Projections not included Panel : 155 x 38 x 70 mm
Body : 140 x 142 x 43 mm
Weight (net) Control Panel
TX/ RX Unit 0.3 kg
1.2 kg
Transmitter
Mid Approx. 10W
Low Approx. 5W
Receiver
45.05MHz / 49.95MHz
455kHz / 450kHz
Selectivity -6 dB
Less than 30kHz
S58T
Prispevkov: 256
OdgovorNapisal/-a s56oa » 08 Avg 2007, 23:41
Še slikica zadeve nastavljene na evropsko APRS frekvenco: :D
Member of S59DGO
OdgovorNapisal/-a s55z » 09 Avg 2007, 08:21
A 435.000 je tudi APRS frekvenca? Pa pri nas ni v uporabi, ne?
Smo v klubu ravno kup UHF FM postaj dobili, ki bi jih lahko preprogramirali na APRS frekvenco...
OdgovorNapisal/-a s56g » 09 Avg 2007, 08:47
Hoj,
Na 70cm naj bi se za APRS v IARU Reg.1 uporabljala frekvenca 433.800
73 de tom*/s56g
p.s.: malo offtopic : frekvence so naslednje:
Koda: Izberi vse
APRS frequencies (for IARU Region 1 ~ Europe)
Band    Carrier Freq  Assigned Freq    Remark
40 m       7.035,0      7.033,5      LSB 300Bd
30 m      10.151,0     10.149,5      LSB 300Bd
20 m      14.104,5     14.103,0      LSB 300Bd
17 m      18.102,0     18.100,5      LSB 300Bd
15 m      21.117,0     21.115,5      LSB 300Bd
10 m      29.250,0     29.250,0      FM 1200Bd
 2 m     144.800,0    144.800,0      FM 1200Bd
70 cm    433.800,0    433.800,0      FM 1200Bd
Na KV je edina uveljavljena frekvenca na 10MHz (LSB)
s56g
Pridružen: 25 Sep 2001, 02:00
Kraj: Nova Gorica, JN65TW
OdgovorNapisal/-a s55z » 09 Avg 2007, 10:13
Hmm, torej bi se dalo na dosedanjih digijih naredit še vstopne točke za 70cm in jih povezat v 2m omrežje?
OdgovorNapisal/-a s56oa » 09 Avg 2007, 11:01
No, saj to glede 70cm sem že jaz razmišljal. Samo folk prevekslat tja ni tako enostavno. Konec koncev je več ali manj celotna Evropa že na 144.800.
Razen če vzamemo v zakup, da gremo infrastrukturo duplicirat - digije, APRS prehode in podobne "malenkosti", pa seveda prepričevat ostalo Evropo za kaj podobnega. :)
Member of S59DGO
OdgovorNapisal/-a s55z » 09 Avg 2007, 12:12
Ravnokar sva bila z Andrejem S56ZAB na kofetku in je razložil, da je 433.800 MHz neuporabna frekvenca zaradi prevelikih motenj in da je v Franciji in Švici v uporabi 439.700 MHz. Če bo vse po sreči, bo še letos nekaj njabolj frekventnih digijev opremljenih s 70cm vhodi...
Vrni se na Packet omrežje
