Stran 3 od 4
Re: uSDX multi band multi QRP postaja
OdgovorObjavljeno: 04 Maj 2021, 20:06
Napisal/-a peterv/s59dkr
takole imam začetek programa
#define VERSION "1.02r"
// Configuration switches; remove/add a double-slash at line-start to enable/disable a feature; to save space disable e.g. CAT, DIAG, KEYER
#define DIAG 1 // Hardware diagnostics on startup (only disable when your rig is working)
//#define KEYER 1 // CW keyer
//#define CAT 1 // CAT-interface
#define F_XTAL 27003150 // 27MHz SI5351 crystal
//#define F_XTAL 25004000 // 25MHz SI5351 crystal (enable for WB2CBA-uSDX or SI5351 break-out board)
//#define F_XTAL 25000000 // 25MHz SI5351 crystal (enable for 25MHz TCXO)
#define SWAP_ROTARY 1 // Swap rotary direction (enable for WB2CBA-uSDX)
#define QCX 1 // Supports older (non-SDR) QCX HW modifications (QCX, QCX-SSB, QCX-DSP with I/Q alignment-feature)
//#define OLED 1 // OLED display, connect SDA (PD2), SCL (PD3)
#define LPF_SWITCHING_DL2MAN_USDX_REV3 1 // Enable 8-band filter bank switching: latching relays wired to a TCA/PCA9555 GPIO extender on the PC4/PC5 I2C bus; relays are using IO0.0 as common (ground), IO1.0..7 used by the individual latches K0-7 switching respectively LPFs for 10m, 15m, 17m, 20m, 30m, 40m, 60m, 80m
//#define LPF_SWITCHING_DL2MAN_USDX_REV2 1 // Enable 5-band filter bank switching: latching relays wired to a TCA/PCA9555 GPIO extender on the PC4/PC5 I2C bus; relays are using IO0.1 as common (ground), IO0.3, IO0.5, IO0.7, IO1.1, IO1.3 used by the individual latches K1-5 switching respectively LPFs for 20m, 30m, 40m, 60m, 80m
//#define LPF_SWITCHING_DL2MAN_USDX_REV2_BETA 1 // Enable 5-band filter bank switching: latching relays wired to a PCA9539PW GPIO extender on the PC4/PC5 I2C bus; relays are using IO0.1 as common (ground), IO0.3, IO0.5, IO0.7, IO1.1, IO1.3 used by the individual latches K1-5 switching respectively LPFs for 20m, 30m, 40m, 60m, 80m
//#define LPF_SWITCHING_DL2MAN_USDX_REV1 1 // Enable 3-band filter bank switching: latching relays wired to a PCA9536D GPIO extender on the PC4/PC5 I2C bus; relays are using IO0 as common (ground), IO1-IO3 used by the individual latches K1-3 switching respectively LPFs for 20m, 40m, 80m
#define SI5351_ADDR 0x60 // SI5351A I2C address: 0x60 for SI5351A-B-GT, Si5351A-B04771-GT, MS5351M; 0x62 for SI5351A-B-04486-GT; 0x6F for SI5351A-B02075-GT; see here for other variants: https://www.silabs.com/TimingUtility/ti ... icAddendum
// Advanced configuration switches
//#define CAT_EXT 1 // Extended CAT support: remote button and screen control commands over CAT
//#define CAT_STREAMING 1 // Extended CAT support: audio streaming over CAT, once enabled and triggered with CAT cmd, 7.812ksps 8-bit unsigned audio is sent over UART. The ";" is omited in the data-stream, and only sent to indicate the beginning and end of a CAT cmd.
#define CW_DECODER 1 // CW decoder
#define TX_ENABLE 1 // Disable this for RX only (no transmit), e.g. to support uSDX for kids idea: https://groups.io/g/ucx/topic/81030243#6276
#define KEY_CLICK 1 // Reduce key clicks by envelope shaping
#define SEMI_QSK 1 // Just after keying the transmitter, keeps the RX muted for a short amount of time in the anticipation for continued keying
#define RIT_ENABLE 1 // Receive-In-Transit alternates the receiving frequency with an user-defined offset to compensate for any necessary tuning needed on receive
#define VOX_ENABLE 1 // Voice-On-Xmit which is switching the transceiver into transmit as soon audio is detected (above noise gate level)
//#define MOX_ENABLE 1 // Monitor-On-Xmit which is audio monitoring on speaker during transmit
#define FAST_AGC 1 // Adds fast AGC option (good for CW)
//#define VSS_METER 1 // Supports Vss measurement (as s-meter option)
//#define SWR_METER 1 // Supports SWR meter with bridge on A6/A7 (LQPF ATMEGA328P) by Alain, K1FM, see: https://groups.io/g/ucx/message/6262 and https://groups.io/g/ucx/message/6361
//#define ONEBUTTON 1 // Use single (encoder) button to control full the rig; optionally use L/R buttons to completely replace rotory encoder function
//#define F_MCU 16000000 // 16MHz ATMEGA328P crystal (enable for unmodified Arduino Uno/Nano boards with 16MHz crystal). You may change this value to any other crystal frequency (up to 28MHz may work)
//#define DEBUG 1 // for development purposes only (adds debugging features such as CPU, sample-rate measurement, additional parameters)
//#define TESTBENCH 1 // Tests RX chain by injection of sine wave, measurements results are sent over serial
//#define CW_FREQS_QRP 1 // Defaults to CW QRP frequencies when changing bands
//#define CW_FREQS_FISTS 1 // Defaults to CW FISTS frequencies when changing bands
#define CW_MESSAGE 1 // Transmits pre-defined CW messages on-demand (left-click menu item 4.2)
//#define CW_MESSAGE_EXT 1 // Additional CW messages
//#define TX_DELAY 1 // Enables a delay in the actual transmission to allow relay-switching to be completed before the power is applied (see also NTX, PTX definitions below for GPIO that can switch relay/PA)
//#define CLOCK 1 // Enables clock
OdgovorObjavljeno: 04 Maj 2021, 20:23
Napisal/-a s57l
Releji so latching. To pomeni, da so preklopljeni tudi takrat, ko nimajo napajanja. Ko vklopis postajo, se vsi releji izklopijo in potem vklopi samo od banda, na katerem si. Ce postajo izklopis iz napajanja, ostanejo releji, kot so bili. Z ohmmetrom preveris, kateri je vklopljen, ce je torej pravi band aktiven.
Po programu mislim da ne rabis define qcx 1, ceprav to nisem zihr...
Ce ne bo delalo, se da tudi sendvic preverit po delih, z drugo, delujoco postajo, sa lociras problematicno plato.
Izhodnih mosfetov imam nekaj na zalogi, ce rabis dobis kakega, sem v lj. Sicer mislim da jih ni problem dobit, ne vem pa kaka je zaloga po trgovinah...
73 janko s57l
OdgovorObjavljeno: 04 Maj 2021, 20:36
ravno gledam software, mogoče imam celo "preveč vklopljenih" stvari.
Izhodnih sem nabavil malo več, ker so res drobiž.
Sem ravno izklopil #define QCX 1, na prvi pogled postaja deluje enako, na lcdju je izginil napis qcx. Sem šel gledal v videe od dl2man in tudi on nima v videu na lcdju tega napisa. Več bom izvedel jutri, ko priklopim na osciloskop v sluzbi.
Se mi pa zdi, da releji vsi preklopijo pri spremembi banda.
preklaplja mi na 80m,60,40,30,20,17,15,12 preskoči, 10, torej sliši se prekljaplanje.
Sem pa začel sestavljati še eno postajco, plat imam dovolj, interesa za njih je bilo pa bolj malo.
Mogoče sva celo našla problem, sporočim jutri (mater se mi bo mudilo na šiht HI)
73 de S51PV
OdgovorObjavljeno: 04 Maj 2021, 20:43
Napisal/-a s57l
Fb, upam da bo delalo...
Mogoce si plate premalo ponujal, jaz sem jih narocil tudi iz usa...
Res pa da sem hotel imet oled.
Mosfeti so drobiz, releji so prav zlatarski :)
Gl s testiranjem
73 janko s57l
OdgovorObjavljeno: 04 Maj 2021, 21:08
dejansko sem jih dobil šele prejšnji mesec, ponujal pa tukaj v postu. sem pa vzel obe varijanti lcdja, imam sestavljenega tudi Oled. Potem sem pogruntal kako svinjsko dragi so ti lcdji 2x16, ki so uporabljeni gor (20€). Tako da releji niso tako zlatarski.
Sem pa naknadno naročil tudi mono band pa plato za eksperimente v prihodnosti. Po najcenejši polžji pošti.
sporočim jutri kako gre.
73 s51pv
OdgovorObjavljeno: 05 Maj 2021, 10:16
problem še vedno ostaja :(
OdgovorObjavljeno: 05 Maj 2021, 18:02
Napisal/-a s57l
Preveri če pravi releji preklapljajo na pravih bandih
OdgovorObjavljeno: 08 Maj 2021, 07:55
releji so preklapljali. Nekdo mi je namignil, da imam mogoče prežgano plato. Ker se mi je to že zgodilo v preteklosti pri nekem drugem projektu sem se lotil selitve materjala. Najbolj zahteven podvig je bila selitev relejev. Ker je plošča še vedno 4 slojna je odspajkovanje relejev s pumpico ali pa bakreno pretenico skoraj nemogoče in zelo zamudno. Tako da sem poguntal metodo, kako rele odspajkat v parih sekundah brez da bi bil poškodovan.
Metodo pa tudi posnel in verjamem, da bo marsikomu ideja prišla prav. Nova plata čaka še poselitev špulc na svoja mesta, potem pa najprej test brez izhodnega tranzistorja, da preverimo filter.
Video: https://youtu.be/GH-ymT4NtQk
OdgovorObjavljeno: 20 Maj 2021, 21:28
še vedno obstaja problem. Ki pa je lokaliziran na matični plošči. že iz driver čipa pride ven dvojna frekvenca. če ga vzamem ven iz podnozja in merim na pinu 1 ali 2 je frekvenca enojna. Sem mislil, da bom z menjavo čipa rešil problem. Na žalost še vedno obstaja. Sem naročil še nekaj čipov in pa sestavil novo matično plato. trenutno čakam še na čipe, sprejemnik pa deluje že brez njega.
https://youtu.be/ZoU3kEUDDB0
dolžina drat antene cca 2m, priključena brez filtrov, ojačevalcev, direktno na sprejemni vhod.
OdgovorObjavljeno: 31 Mar 2022, 06:06
Napisal/-a s56al
Primerek (tr)uSDX, zgrajen iz kompleta, kupljenega na Aliexpressu:
5 obsegov (3,5 do 14 MHz), SMD elementi so že pricinjeni na obe tiskanini. Na toroidna jedra je treba naviti 13 tuljav ter priciniti vse elemente, ki se na TIV montirajo skozi luknjice. Potrebna je tudi manjša predelava priloženega OLED.
Deluje "s prve" in po pričakovanjih. V mikrokontrolerju iz kompleta je bil bootloader že naložen.
Pri napajanju 12V je na vseh 5 obsegih na antenskem priključku med 5 in 6 W oddajne moči. Le BP sito za 40m je (vsaj pri mojem primerku ter brez posebnega uravnavanja) izpadlo nekoliko "zamaknjeno" navzdol, tako da maksimalno izhodno moč oddaje doseže pri 7,0 MHz, pri 7,2 MHz pa že pade na slabe 4 W. Filtri na ostalih obsegih so lepo "poravnani". Kar je posebej pohvalno, vgrajena meritev moči oddaje deluje presenetljivo točno.
Kratek video posnetek sprejema CW @ 40m!
OdgovorObjavljeno: 31 Mar 2022, 06:31
Napisal/-a s58db
Lepo narejeno,
tudi sam imam doma komplet ploščic za katere upam, da bojo nekega dne poseljene. Me pa skrbi dobava drobnega materiala.
Drugače pa je tudi avtor tega sprejemnika/oddajnika naredil en video v katerem je sestavljal kitajski klon svojega sprejemnika. Zanimivo, da jih je celo pohvalil :) .
Ne spomnim se kje sem zasledil ta video. Mogoče celo na tem forumu.
https://www.youtube.com/watch?v=hLCFsNNDZUg
OdgovorObjavljeno: 31 Mar 2022, 09:16
Napisal/-a s56al
Hvala, Danilo :)! Material iz teh kitajskih KIT kompletov je videti solidne kvalitete, kar je potrdil tudi avtor v videoposnetku, ki si ga pripel. Če samostojno nabavljaš komponente, je nabava vseh SMD kosov najbrž kar sitno opravilo, sploh če nabora vsaj najbolj standardnih vrednosti C in R nimaš že doma.
Po tem, kar sem videl pri sestavljanju iz kompleta, je pomembno, da se v filtre vgradi kvalitetne in preverjene kondenzatorje, toleranca 5%. Enako velja za toroidna jedra. Danes je na trgu cel kup jeder, ki se prodajajo kot Amidon. Ni nujno, da so vsa slaba, zagotovo pa vsa niso originali. Pri nabavi iz nepreverjenega vira je v izogib kasnejšim težavam jedra pred navijanjem tuljav oz. vgradnjo smiselno preveriti. Na par vzorcev naviti 10 ovojev žice ter preveriti vsaj induktivnost, ali je znotraj pričakovanega odstopanja.
Kar se moram še naučiti, je na pokrov ohišja natisniti besedilo v drugačni barvi ;)!
OdgovorObjavljeno: 31 Mar 2022, 10:11
Napisal/-a s55m
Ampak Sandi, znas tudi lepse :)
Tinka
OdgovorObjavljeno: 11 Apr 2022, 15:51
Napisal/-a s56al
Hvala, Adi!
Bliža se Velika noč ;)!
OdgovorObjavljeno: 12 Apr 2022, 09:25
Napisal/-a s55m
Sandi, ne vem zakaj me plastika ne fascinira. Izgleda mi tako, kot so včasih izgledali kitajski low cost plastični izdelki. Malo aluminija zvitega kar na predalniku mi vliva več zaupanja :)
