HAARP & odboj od asteroida
OdgovorNapisal/-a s56al » 24 Dec 2022, 09:23
Zanimiv eksperiment v okviru projekta HAARP, v nadaljevanju pripenjam sporočilo v celoti.
Vsem vesele praznike ter srečno in zdravo novo leto 2023!
SB SPCL ARL ARLX012
ARLX012 Amateur Radio Operators Invited to participate in Asteroid
Bounce Experiment
The High-frequency Active Auroral Research Program (HAARP) will be
conducting a research campaign/experiment on December 27, 2022, with
transmissions between 1100 - 2300 UTC (0200 - 1400 AKST).
This experiment will reflect HAARP transmissions off of Near-Earth
Asteroid (NEA) 2010 XC15, and the echo will be received by the Owens
Valley Radio Observatory Long Wavelength Array (OVRO-LWA) at the
California Institute of Technology (Caltech) and by the University
of New Mexico's Long Wavelength Array (UNM-LWA). The target asteroid
will be roughly two lunar distances away from Earth at the time of
transmission. Characterizing the interior structure and composition
of NEAs is critical for advancing the understanding of solar system
evolution and aiding in planetary defense.
Actual transmit times are highly variable based on real-time
ionospheric conditions and all information is subject to change.
Currently, the Asteroid Bounce (2010 XC15) experiment will take
place December 27, 2022, from 1100 UTC to 2300 UTC; 9.6 MHz, LFM
(linear FM), 0.5 Hz WRF (waveform repetition frequency), 30 kHz
bandwidth. Reports recording echo are encouraged; demodulated
recordings in .WAV or .MP3 are recommended.
For real-time ionospheric conditions in Gakona, please consult
ionograms from the HAARP Diagnostic Suite at,
https://haarp.gi.alaska.edu/diagnostic-suite .
Amateur radio and radio astronomy enthusiasts are invited to listen
to the transmissions/echoes and submit reception reports via email
to the HAARP facility at, uaf-gi-haarp@alaska.edu, and request a QSL
card by mailing a report to:
HAARP
P.O. Box 271
Gakona AK 99586
USA
Pridružen: 03 Jul 2001, 01:00
Re: HAARP & odboj od asteroida
OdgovorNapisal/-a s57uw » 24 Dec 2022, 11:04
HI ! Malo bom prisluhnil. HNY GL A
Vsem čim več dobrega !
s57uw
Prispevkov: 256
Pridružen: 27 Jan 2006, 14:14
Kraj: Velika Polana
OdgovorNapisal/-a S51B » 27 Dec 2022, 18:25
Mogoče ne bo pritožb, ker je tema pač izven naše domene pa vendar.
Omenjeni poskus mi je zanimiv ampak a ni malo iluzorno pričakovat, da se bo signal kratkega vala
odbil od asteroid, če vemo, da je ionosfera "živi ščit na tej frekvenci. Že res da gre za mega vate
pa vseeno se mi zdi čudno. Tudi če prebiješ ionosfero bi bil morda problem odbitega signala.
Al pa jaz kaj ne razumem?!?
73 de S51B Brane
S51B
Prispevkov: 27
Pridružen: 18 Jun 2018, 22:18
OdgovorNapisal/-a s57bat » 27 Dec 2022, 21:16
A se mi samo zdi, ali pa je to precej amatersko?( ne radioamatersko HI). Na tej frekvenci oddaja Radio China International.
s57bat
Prispevkov: 101
Pridružen: 12 Jul 2004, 06:57
OdgovorNapisal/-a S51B » 27 Dec 2022, 23:48
He he...to sem se tut jaz spraševal. Poskusi med dvema radijskima postajama z mega vati.
Sem poslušal. Čez dan pa celo točno na postaji. Tak da ne vem kdo je tu nor?!?
Srečno 2023 de S51B Brane
S51B
Prispevkov: 27
OdgovorNapisal/-a s57uw » 31 Dec 2022, 19:37
Sem poslušal. haarpa ne zaznal, razen eno AM postajo okoli 15 ure. Glazba,toda govora ne prepozna, qsb.
Pogoje na KV navadno pogledam na "DR2W" strani. do popoldneva Canada ni bila pokrita, ko je pa bila je bilo brez signalov. Pa drugič !
s57uw
Prispevkov: 256
Kraj: Velika Polana
