ARISS SSTV
ARISS SSTV
OdgovorNapisal/-a s56al » 06 Avg 2021, 07:22
Danes (petek) popoldne in jutri:
ZCZC AS09
QST de W1AW
Space Bulletin 009 ARLS009
From ARRL Headquarters
Newington, CT August 2, 2021
To all radio amateurs
SB SPACE ARL ARLS009
ARLS009 SSTV Transmissions Scheduled from ISS
Friday and Saturday, August 6 - 7, Russian cosmonauts onboard the
International Space Station (ISS) will transmit slow-scan television
(SSTV) images from the station on 145.800 MHz FM. They will use SSTV
mode PD-120. The transmissions are part of the Moscow Aviation
Institute SSTV experiment (MAI-75) and will be sent via RS0ISS, the
ham station in the Russian Zvezda (Service) module using a Kenwood
TM-D710 transceiver.
The announced schedule is August 6, 1050 - 1910 UTC and August 7,
0950 - 1555 UTC. Dates and times are subject to change. For stations
in the ISS footprint, the RS0ISS signal should be easy to copy on a
handheld transceiver and a quarter-wave whip. Use 25-kHz channel
spacing, if available. Free ISS software is available to download.
Pass predictions are available from AMSAT via,
https://www.amsat.org/track/ .
Representative images from prior ISS
SSTV events are available in the ARISS SSTV Gallery at,
https://www.spaceflightsoftware.com/ARI ... /index.php .
Re: ARISS SSTV
OdgovorNapisal/-a S56BL » 06 Avg 2021, 20:20
Hvala, današnji prelet 20:07 sem seveda zadnjo minuto prišel in preden sem spet naštudiral nastavitve sem sprejel 1/5 slike :D
Bom še jutri probal HI
S56BL
Prispevkov: 40
Pridružen: 10 Jan 2019, 15:05
Re: ARISS SSTV
OdgovorNapisal/-a s52o » 06 Avg 2021, 20:36
Diplome so tudi že.
S52O ZVONE PIVK InSpacE SSTV Diploma August 21-page-001.jpg (110.92 KiB) Videno 7894 krat
s52o
Prispevkov: 409
Pridružen: 02 Sep 2004, 22:04
Kraj: Hotavlje JN76BC
Re: ARISS SSTV
OdgovorNapisal/-a s56al » 06 Avg 2021, 21:14
CONGRATS, so pa ekspeditivni :)!
Meni je žal uspelo sprejeti le 3 delne. Tu pri meni doma (tik pod Pohorjem na severni strani) je dobršen del neba proti J in JZ zakrit. Signal se pojavi šele 3 do 5 minut zatem, kot ga naračuna "kalkulator". Upam na več sreče jutri...
Re: ARISS SSTV
OdgovorNapisal/-a S56BL » 07 Avg 2021, 11:25
Zdele nič je bila nad Turčijo bi skor mogu kej slišat.
Kakšne imate antene, jaz imam 5el yagi horizontalno postavljena na rotatorju.
S56BL
Prispevkov: 40
Re: ARISS SSTV
OdgovorNapisal/-a s56al » 07 Avg 2021, 11:31
Antene so na eni lokaciji kratka 3 el. yagi, obrnjena "krnekam" v hrib, na drugi pa 6m "HB9" ;). Žal so "napoti" hribi. Ko je, je signala v izobilju. Tudi na vokič in "gumico" na balkonu se dobro sliši...
Za danes imam zabeležene aktualne čase preleta: 10:51, 12:28, 14:05 in 15:42, vse po UTC.
GL in 73 de S56AL
P.S.: Enkrat ponoči so med enim od preletov "odvrgli" tudi mojo diplomo ;)!
Re: ARISS SSTV
OdgovorNapisal/-a S56BL » 07 Avg 2021, 12:19
Bravo!
Ne sprejemam prvič, sem že večkrat sprejel če se ne motim 7 slik od 12, zato mi je bilo čudno da ni bilo nič slišat.
Naslednji prelet bom še spremljal, ker je blizu, da imam kakšno frišno sliko :D
Tako kot si rekel, ko je signal ga ujame vse. Če imaš dobro anteno začneš sprejemat toliko prej, potem je spet odvisno v katero okno oddaje padeš. Če imam srečo lahko dobim dve slike na prelet ampak redko, ponavadi pol ene - drugo celo- pol tretje HI
S56BL
Prispevkov: 40
Re: ARISS SSTV
OdgovorNapisal/-a s56al » 07 Avg 2021, 12:49
Nastaviš MMSSTV in s kozarcem v roki v senci čakaš, da se kaj ujame :)! Je pa v teh poletnih dneh pametno biti kje blizu, da greš odklopit anteno, če se od kje priklati kaka nevihta. Glede slik pa, kot si napisal, zadnje pol ene in prvo polovico naslednje... ;)!
Re: ARISS SSTV
OdgovorNapisal/-a s56zvd » 09 Avg 2021, 14:45
Slučajno sem naletel na tole.
https://telanganatoday.com/hyderabad-ha ... -satellite
Mogoče bo še zanimivo.
Matjaz
s56zvd
Prispevkov: 164
Pridružen: 19 Jun 2004, 20:01
Re: ARISS SSTV
OdgovorNapisal/-a S56BL » 10 Avg 2021, 21:06
s56zvd napisal/-a:Slučajno sem naletel na tole.
Matjaz
Sicer iz ISS SSTV nima veliko skupnega ampak zelo zanimiva zadeva. Vedno so me zanimali sateliti, če bo to vse skupaj za nabavit za manj kot 200-300€ bo spet za pol leta veselja :D
Lp
S56BL
Prispevkov: 40
