4th EPC PSK63 QSO Party 2009
OdgovorNapisal/-a s55z » 17 Nov 2009, 11:24
Dear Fellow Radio Amateurs,
The European PSK Club has the honour to invite the radio amateurs all over
the world to participate in the 4th EPC PSK63 QSO Party 2009.
Starting time is at 00:00 UTC, and ending time is at 24:00 UTC on Sunday 22 November,2009.
The rules and other information can be found at our website.
It is strictly BPSK63 contest, no other modes are allowed.
The maximum output power is 100 watts.
Recommended frequencies are: 160 meters (1.838 - 1.843 MHz),
80 meters (3.580 - 3.590 MHz), 40 meters (7.040 - 7.050 MHz),
20 meters (14.070 - 14.080 MHz), 15 meters (21.070 - 21.080 MHz),
and 10 meters (28.070 - 28.080 MHz).
All the very best and see you all in the Party!
73! de European PSK Club
EPC PSK63 QSO Party Committee
Re: 4th EPC PSK63 QSO Party 2009
OdgovorNapisal/-a S53K » 17 Nov 2009, 20:01
tnx info Dragan!
CU !
73 Simon, S53K
S53K
Prispevkov: 341
Pridružen: 02 Jul 2001, 02:00
Kraj: JN75RX
OdgovorNapisal/-a S51AY » 19 Nov 2009, 21:59
Vse potrebno za to tekmovanje najdete tu : http://eu.srars.org/ , na levi strani, v stolpcu "EPC PSK63 QSO PARTY"
GL, CU
OdgovorNapisal/-a s55z » 20 Nov 2009, 15:52
Dear Fellow PSK Contesters!
Victor, RA3BB has created a new set of files for MixW data mode software to make your particiapation in the EPC PSK63 QSO Party 2009
most enjoyable. You can download this set of files at Victor's website at http://www.digitalrus.ru or directly from this link http://www.eu.srars.org/psk63/StatsEUEPC.zip
Unzip the files, and place all of them into the Plugins folder of the MixW software.
That's it, nothing else is required to be done apart from the correct contest setup as described at
http://eu.srars.org/index.php?option=co ... Itemid=155
After this cunning modification MixW will automatically update EPC data files
(call.dat and epc.dom) every time you run the software.
At the moment we have approximately 9,700 call signs in 159 DXCC countries World Wide registered with the European PSK Club.
All six continents are represented. We hope that this year the EPC PSK63 QSO Party will be busier than ever. Have a nice weekend guys,
and see you all in the Party on Sunday, 22nd November, 2009!
73!
European PSK Club
www.eu.srars.org
OdgovorNapisal/-a S51AY » 25 Nov 2009, 10:17
Hoj !
V logu imam 6 SLO postaj, še nekaj sem jih slišal, ampak ni bila njihova frekvenca. Kako ste "preživeli" ? Pri meni je situacija na grobo 677 QSO in ca. 1.9M točk. Letos bo sigurno prebita magična meja 2M. Čudna situacija na 20m , malo bolje na 80/40m.
OdgovorNapisal/-a S53K » 25 Nov 2009, 20:16
S51AY napisal/-a:Hoj !
Arpi čestitke...sam sem delal samo 7MHz, lepa zabava... pileupsi pa neverjetni... hi
Summary:
Band QSOs Mults
160:
80:
40: 340 315
20:
15:
10:
Total: 340 315 Total Score = 504,000
se "vidimo"
73 Simon, S53K
S53K
Prispevkov: 341
Kraj: JN75RX
OdgovorNapisal/-a S51AY » 25 Nov 2009, 21:02
Simon, super ! Se vidimo ! Kakšno pivo že piješ, Union ali Laško ? :D OK, lahko tudi kava, kot navadno.
Moral bom še malo pregledati, nekajkrat mi je v call polje uletela tipka "tilda" (pod Esc). Utrujenost... Po bandih je situacuja "trenutno" taka:
Band : QSO - QSO pts - Mult
80 : 263 - 1194 - 233
40 : 211 - 995 - 196
20 : 170 - 798 - 157
15 : 33 - 153 - 30
3140 x 616 = 1.934.240
Premalo sem spal (30min 12s), pa sem potem zaradi preutrjenosti zgubil več, kot bi s spanjem...
OdgovorNapisal/-a S53K » 25 Nov 2009, 22:54
S51AY napisal/-a:Simon, super ! Se vidimo ! Kakšno pivo že piješ, Union ali Laško ? :D OK, lahko tudi kava, kot navadno.
15 : 33 - 153 - 30
ko bom spet kaj v tvojih koncih vsekakor :)... če praviš pivo potem je union, če bi rekel pir, potem Laško... :)
ma je letelo...ko sneta sekira... lepi DXi in velika EPC udeležba, presentljivo od vseh 340Q, jih samo 25 ni bilo :)
se vidimo, če ne prej pa OK/OM RTTY decembra...
73 Simon, S53K
S53K
Prispevkov: 341
Kraj: JN75RX
