The 3rd EPC PSK63 QSO Party 2008
OdgovorNapisal/-a S51AY » 09 Nov 2008, 19:25
Ker sem že tretjič dobil povabilo od UT7FP, sem se odločil, da tu objavim ta opomnik. Upajmo, da bo koga zanimalo.
Ne bi tu lepil teksta v angleščini, gre pa za to, da bo v nedeljo, 16.11.2008 tekmovanje "EPC PSK63 QSO Party".
Propozicije najdete tukaj : http://eu.srars.org/index.php?option=co ... Itemid=141
Zanimivost je tudi ekipno tekmovanje "Team Challenge" (največ 5 tekmovalcev v ekipi), vsak član zmagovalne ekipe prejme steklenico "Scottish Whisky"-ja ; http://eu.srars.org/index.php?option=co ... Itemid=160 .
Vse potrebno za tekmovanje (datoteke članov, itd.) najdete na tej strani http://eu.srars.org/index.php?option=co ... Itemid=144 .
Nisem se še čisto odločil za sodelovanje, če bi nas pa bilo dovolj, bi me tista flaša "kačje sline" kar premamila... :P Ampak, ekipo bi bilo treba prijaviti do 13. Novembra ob 24:00 UTC.
Re: The 3rd EPC PSK63 QSO Party 2008
OdgovorNapisal/-a s57yx » 10 Nov 2008, 17:58
Jaz sem ZA !
EPC #2639
73 de Slavko !
s57yx
Prispevkov: 120
Pridružen: 09 Feb 2007, 02:22
Kraj: SEŽANA
OdgovorNapisal/-a s57aj » 10 Nov 2008, 20:39
The EPC PSK63 QSO Party Team Challenge
The main idea was borrowed from the TARA PSK Rumble.
General Rules
Each team has to select a Gaffer, a team leader, whose responsibility is to complete a team and to submit the team's information to the EPC Contest Committee. Since each team member is also encouraged to submit a non-team, individual entry, <Single Operator - Single Transmitter> operation is the only operating category allowed in the EPC PSK63 QSO Party. Any individual can only be a member of one team. Each team is allowed up to 5 members.
Members can be spread geographically. The smart Gaffer will probably select a DX diversified team to enhance the team's multipliers. Each team must declare its Name and each of its members' names and call signs, at least 48 hours before contest kick-offs. You can add and drop members from the Team up until this dead line (24:00 UTC, 13th November 2008) . Then the Teams will be frozen. These declarations will be posted on the special <EPC PSK63 QSO Party Team Challenge> web page along with the teams other declarations.
The team Gaffer can throw a challenge to another team indicating that they will <whip them> royally in the contest. If accepted by the other team, this challenge will be posted in the team's declaration on the web page mentioned above. The winning team will add 500 points to its total and the loosing team subtracts 500 points. A maximum of 3 teams can be challenged by a single team for a total of +/- 1500 <whip them> points on the final score.
Since the Teams total scores are important for applying the challenge bonus points to the Grand Totals, we ask the Gaffers to make sure the members submit their logs correctly and on time. To keep things focused please keep all the contest banter on the EPC Google News Group.
Any score submission received that indicates Team Challenge Category but the member does not appear on the teams declaration, will not be included with the Team, and will be entered as an individual entry only. Teams can find their relevant declarations and member list posted on the special <EPC PSK63 QSO Party Team Challenge> web page.
You can start to complete your team right away and submit your details to us via email This e-mail address is being protected from spam bots, you need JavaScript enabled to view it . Make sure that you provide all the necessary information, such as your Team's name, members' call signs, and a team or teams you are going to challenge.
All the very best and 73!
EPC PSK63 QSO Party Contest Committee
http://www.eu.srars.org
Jaz sem ZA
S57AJ EPC # 2651
s57aj
Prispevkov: 22
Pridružen: 17 Jun 2003, 19:41
Kraj: Idrija
OdgovorNapisal/-a S51AY » 10 Nov 2008, 21:07
Še dva...
OdgovorNapisal/-a S50DX » 17 Nov 2008, 09:08
Hi All,
Fresh MixW Contest Setup Files have been uploaded a few minutes ago to the server at http://eu.srars.org/psk63/mixw/mixw-psk63.zip Please download them and replace your old files to be up to date. Keep the structure as it's in the .zip file.
Another info... We have cancelled the Team Challenge this year. Just do your best for yourself.
Good luck and 73!
de MM0DFV
Jurij
Prispevkov: 468
Pridružen: 23 Apr 2003, 14:46
OdgovorNapisal/-a S53K » 17 Nov 2008, 17:06
lepa aktivnost, dober pile up na 40m... kdo bi si mislil...
škoda, da ni bilo časa za celo tekmovanje...
73 Simon
S53K
Prispevkov: 341
Pridružen: 02 Jul 2001, 02:00
Kraj: JN75RX
OdgovorNapisal/-a S51AY » 17 Nov 2008, 18:17
Tudi jaz sem presenečen. Moj prvi PSK63 contest. Sicer ob nepravem času, ampak... Super, mnogo ožje od npr. RTTY, pa precej hitrejše. Za info: 600 QSO, pa okoli 1.2M točk. Pa še za 4 ure sem proti jutru zaspal... Pravi contest !
OdgovorNapisal/-a S53K » 17 Nov 2008, 20:52
S51AY napisal/-a:Tudi jaz sem presenečen. Moj prvi PSK63 contest. Sicer ob nepravem času, ampak... Super, mnogo ožje od npr. RTTY, pa precej hitrejše. Za info: 600 QSO, pa okoli 1.2M točk. Pa še za 4 ure sem proti jutru zaspal... Pravi contest !
si pa bil priden, te nisem nič slišal, sicer pa v nedeljo dopoldan na 40m vrjetno niti ne bi šlo...hi
contest je res pravi... je pa zanimivo, da ga ni na 3830 reflektorju... veliko je bilo EPCjev, od 100qso mislim, da jih ni bilo 5, ki niso "še" niso člani...hi
73 Simon
S53K
Prispevkov: 341
Kraj: JN75RX
OdgovorNapisal/-a S51AY » 18 Nov 2008, 01:12
Ja, S5 niti jaz nisem slišal. Pravzaprav, enkrat sem slišal S57AJ, ko je nekoga klical. Take propagacije pač. Res pa je, da ni bilo neke potrebe po pogostem S&P, vedno je kaj priletelo na CQ, da o pileupih ne govorim. Zanimivo pa je, da se je celo proti koncu tekmovanja splačalo klicati CQ. Pa na S&P se je dalo doseči dober rating, skoraj kot na CQ. Testiral sem še eno zadevo, ki jo omogočajo makroji v MixW. Sprogramiral sem mu neke CAT ukaze za vklop raznih filtrov za boljši sprejem, izluščenje in "dvig" šibkih signalov, vse z pritiskom ene tipke. No "dvig" je po potrebi na drugi tipki. Super dela, je pa samo za FT-2000. Če koga zanima... Ni več "vojna tajna".
OdgovorNapisal/-a S53K » 20 Nov 2008, 00:53
S51AY napisal/-a:Ja, S5 niti jaz nisem slišal. Pravzaprav, enkrat sem slišal S57AJ, ko je nekoga klical. Take propagacije pač. Res pa je, da ni bilo neke potrebe po pogostem S&P, vedno je kaj priletelo na CQ, da o pileupih ne govorim. Zanimivo pa je, da se je celo proti koncu tekmovanja splačalo klicati CQ. Pa na S&P se je dalo doseči dober rating, skoraj kot na CQ. Testiral sem še eno zadevo, ki jo omogočajo makroji v MixW. Sprogramiral sem mu neke CAT ukaze za vklop raznih filtrov za boljši sprejem, izluščenje in "dvig" šibkih signalov, vse z pritiskom ene tipke. No "dvig" je po potrebi na drugi tipki. Super dela, je pa samo za FT-2000. Če koga zanima... Ni več "vojna tajna".
tako kot praviš glede 40m..
sam sem se ukvarjal z nastavitami n1mm za to tekmovanje, a striček google pomaga...hi več nas je "našlo" bug, a tudi rešitev.
Za naslednje leto pa vrjetno kaj resneje. za ft1k obstaja tudi SW, s katerim izbiraš filtre v postaji...torej tudi lsb, usb z 500Hz oz. 250 :)
S53K
Prispevkov: 341
Kraj: JN75RX
OdgovorNapisal/-a s55z » 20 Nov 2008, 01:10
Simon, kako si prepričal N1MM da je delal ta ctest??
OdgovorNapisal/-a S51AY » 20 Nov 2008, 10:49
Hoj !
N1MM ima "vgrajen" ta contest, ampak tudi mene zanima, kako si z njim delal na PSK. Obstaja kakšen PSK modul za N1MM ?
Ja, najvažnejši je sprejem, kakor tudi pri PSK31. Jaz sem uporabljal širino 150-200 Hz, razen pri močnih signalih na S&P. Zvok imam speljan preko audio vhoda/izhoda, tako da se normalno uporablja SSB mode. SSB filter pa nima dovolj strme karakteristike, kar se najbolj vidi pri razmazanih robovih signala na Waterfall-u, pa lahko ga ožim samo do 200Hz (pri CW filtru do 50Hz). Ugotovil sem, da je najboljši sprejem na CW, z "ostrejšim" CW filtrom. Samo, potem je treba oddajati Split na SSB, frekvenca je premaknjena... Tisto "čarobno tipko" pritisnem, ko sem se postavil na nekoga. S tem sprožim MixW funkcijo "Align", ga potegne na nastavljeno zvočno frekvenco, izenačim frekvenci VFO A = VFO B, vklopim VFO A na CW (1. sprejemnik), vklopim CW filter, vklopim VFO 2 na SSB (2. sprejemnik + oddajnik), premaknem frekvenco VFO B, koliko je premaknitev CW-SSB, vklopim Split, Shift premaknem na točko, kot je nastavljen Pitch, v grobem je to. Naknadno se lahko še ročno regulira Width - po potrebi (na PSK31 lahko ožim do 100Hz, pa še sprejema !). Vse to s pritiskom ene Macro tipke v MixW. Z drugo tipko pa vse to izklopim. Ker pa ima MixW precej Macrojev, sta dva še za vklop Contour (najboljša stvar pri šibkih signalih) in DNR, po potrebi. To sem naredil za FT-2000, sigurno bi se dalo tudi za druge postaje, kjer CAT to omogoča.
Zadnjič spremenil S51AY, dne 20 Nov 2008, 13:46, skupaj popravljeno 1 krat.
OdgovorNapisal/-a s55oo » 20 Nov 2008, 11:57
FT 1000mp uporabnikom bi tole lahko prav prislo...Malo se bo za poigrat.
http://lea.hamradio.si/~s53rm/FT-1000MP%20WSJT.htm
Goran ANDRIC, S55OO
s55oo
Prispevkov: 261
Pridružen: 02 Avg 2001, 02:00
Kraj: Domzale
OdgovorNapisal/-a S51AY » 20 Nov 2008, 14:05
Aha, Simon, ti si verjetno uporabljal N1MM + MMVARI engine...
OdgovorNapisal/-a S53K » 20 Nov 2008, 22:58
S51AY napisal/-a:Aha, Simon, ti si verjetno uporabljal N1MM + MMVARI engine...
tako tako...
73 Simon
S53K
Prispevkov: 341
Kraj: JN75RX
