NOVA VER. MMTTY 1.66F
OdgovorNapisal/-a S58F » 04 Sep 2008, 21:48
Končno je po treh letih izšla nova verzija MMTTY 1.66F!!!
Dobite jo na:http://www.dxlabsuite.com/MMTTY/mmtty166F.zip
73 ERIK S58F
"LIFE IS TO SHORT TO BE QRP"
EX-S57LWE
S58F
Prispevkov: 222
Pridružen: 14 Mar 2003, 23:24
Kraj: GOČE-VIPAVA
Re: NOVA VER. MMTTY 1.66F
OdgovorNapisal/-a S53K » 05 Sep 2008, 00:14
tnx info
73 Simon
S53K
Prispevkov: 341
Pridružen: 02 Jul 2001, 02:00
Kraj: JN75RX
OdgovorNapisal/-a s57yx » 05 Sep 2008, 19:47
Živ Erik !
Zanima me kaj prinaša nova verzija, kot si napisal, po treh letih.
A vmes od 1.65D.............do 1.66F pa nič.
Vseeno hvala za objavo.
73 de Slavko !
s57yx
Prispevkov: 120
Pridružen: 09 Feb 2007, 02:22
Kraj: SEŽANA
OdgovorNapisal/-a S53K » 05 Sep 2008, 20:10
s57yx napisal/-a:Živ Erik !
zraven .exe je tudi .txt in sicer :
MMTTY version 1.66F release note
2008-08-17
1. Changes to the "MMTTY Setup" window
A. "TX" tab
- renamed the "PTT" panel to "PTT & FSK" (tnx to Joe W4TV)
- added com8 through com16 to the "PTT & FSK" panel's "Port" selector (tnx to Oba-san JA7UDE)
- clicking a button in the "Input Button" panel from a non-Japanese locale displays a window entitled "Edit Button" (tnx to Joe W4TV)
B. "Misc" tab
- the new "Device Identifiers" panel enables independent selection of soundcard devices for reception ("RX") and transmission ("TX"); any of 16 input and output soundcard devices can be selected (tnx to Gil W0MN and Joe W4TV)
- selecting an "RX" or "TX" device identifier in the "Device Identifiers" panel updates the respective "Reception" or "Transmission" panels shown on the new "Soundcard" tab
C. "Soundcard" tab (new)
- the "Reception" panel shows all installed soundcard input devices; selecting an input device updates the "RX" selector in the "Misc" tab's "Device Identifiers" panel
- the "Transmission" panel shows all installed soundcard output devices; selecting an output device updates the "TX" selector in the "Misc" tab's "Device Identifiers" panel
2. Changes to the "Radio Command" window
- added com8 through com16 to the "Port" selector (tnx to Oba-san JA7UDE)
- added 38400 and 57600 to the "Baud" selector (tnx to Joe W4TV)
- named the selector in the lower-left corner "Group"
- modified the contents of the "Group" selector:
*** renamed the previous "Yaesu HF? (FT-1000MP,...)" entry to "Yaesu FT 1000D, 1000MP, 920"
*** renamed the previous "Yaesu VU? (FT-736,FT-847)" entry to "Yaesu FT 736, 817, 847, 857, 897"
*** added a "Yaesu FT 9000, 2000, 950, 450" entry (tnx to Joe W4TV and Art W2NRA)
*** renamed the previous "Kenwood" entry to "Kenwood, Elecraft" (tnx to Joe W4TV)
- renamed the "Commands" panel's "VFO Polling" selector to "Model", and added entries for the Yaesu FT 9000, 2000, 950, and 450 (tnx to Joe W4TV)
3. Other notes
A. As before, changes made to settings shown in the "Radio Command" and "MMTTY Setup" windows do not take effect until the window is closed by clicking its "OK" button.
B. On Vista, log into the account named Administrator before installing or running MMTTY
C. the updated online help was developed by Joe W4TV with help from Al VE4ABU
C. 1.66F is a software-only upgrade, meaning that you must already have MMTTY installed. I will develop an installer for use with PCs that don't yet have MMTTY installed. If you want to install 1.66F on a PC that doesn't yet have MMTTY installed, first install version 1.65D, and then upgrade as described below.
D. To upgrade an existing MMTTY installation to 1.66F, download the zip archive from
The archive mmtty166F.zip contains three files: mmtty.exe, mmtty.chm, and 1.66F.txt
Place mmtty.exe and mmtty.chm in your MMTTY folder, replacing the existing files, and then run mmtty.exe
The file 1.66F.txt contains a copy of this release note.
73 Simon
S53K
Prispevkov: 341
Kraj: JN75RX
OdgovorNapisal/-a s57yx » 06 Sep 2008, 09:08
Hoj Simon !
TNX ! :D
73 de Slavko !
s57yx
Prispevkov: 120
Kraj: SEŽANA
Po forumu brska: 0 registriranih uporabnikov in 34 gostov
