Napisal/-a S50DX » 03 Okt 2005, 09:57
S prihodom MixW 2.16b5 verzije, se je povečala tudi uporaba te oblike dela.
Za lažje delo in čim manj moten, se priporoča naslednje:
Olivia on Mixw seems to be runner. To avoid further chaos on 20 meter, here a few hints!
- Leave 14109.500 Khz free for MT63. (Some new MT63 stuff may be in the pipeline)
- Use channels from 14108.500 Khz down to 14101.500 Khz in exact 1 Khz steps.
- Make sure you have set 1000Hz frequency at the Mixw bottomline, when using 1000/32 mode.
- Avoid using Manuel tuning - not needed.
- Check your transceiver frequency accuracy.
- Use WWV or 14995.000 Khz USB to see a signal at 1000 Hz (Waterfall)
- Avoid tuning on the TRX dail during reception, just leave it fix.
- Mixw Olivia copys inbetween +/- 60 Hz perfect.
- Never transmit at 14108.000 Khz or any other odd frequency, or you jam two adjacent channels.
- When strong adjacent channels and AGC gave up, if possible, use a narrow 500 Hz filter.
- Olivia can copy 100% with only 50% channel information. (Try it out).
Vir: MixW reflektor - Chris Gerber , hb9bdm
