FT8 v2
FT8 v2
OdgovorNapisal/-a S55DX » 04 Jan 2019, 12:45
Moj prehod na FT8 v2 je minil neboleče - brez branja navodil. :D Nekaj zvez je že logiranih, tako v navadnem kot tudi F/H načinu.
Se mi pa ob zagonu WSJT-X programa pojavi pop-up okence, ki pravi, da ni bilo mogoče naložiti podatkov o LotW uporabnikih zaradi omrežne napake pri SSL handshake-u. Okence zaprem in program nemoteno uporabljam naprej. OS je Win 8.1, internetna povezava pa preko WiFi routerja.
Ali lahko kaj naredim, da se bodo "manjkajoči" podatki naložili oziroma, da se okence ne bo odpiralo?
73 de Milan, S 5 5 D X
S55DX
Prispevkov: 615
Pridružen: 08 Jan 2003, 20:56
Kraj: Jezero (JN75fx)
Re: FT8 v2
OdgovorNapisal/-a s55oo » 04 Jan 2019, 13:13
https://physics.princeton.edu/pulsar/k1 ... -X_2.0.pdf
LoTW Download Errors: If you are using Windows and experience LoTW download
errors, go here https://slproweb.com/products/Win32OpenSSL.html and download the
OpenSSL installer, specifically the “Win32 OpenSSL v1.0.2p Light” version. Note that
this is the correct version even if you are running 64-bit Windows. The direct download
link is https://slproweb.com/download/Win32Open ... 1_0_2q.exe. Run the
installer with all default options and accept the option to install into the Windows system
directory. If you cannot install the OpenSSL libraries or do not have an Internet
connection on the computer used to run WSJT-X 2.0, you can download the LoTW file
manually. Go to https://lotw.arrl.org/lotw-user-activity.csv in a web browser, download
the file, then move it to the WSJT-X log files directory. This directory can be opened by
selecting File | Open log directory.
73 HNY
Goran ANDRIC, S55OO
s55oo
Prispevkov: 261
Pridružen: 02 Avg 2001, 02:00
Kraj: Domzale
Re: FT8 v2
OdgovorNapisal/-a S55DX » 04 Jan 2019, 13:18
Tnx Goran, bom poskusil. :D
HNY
S55DX
Prispevkov: 615
Re: FT8 v2
OdgovorNapisal/-a S55DX » 04 Jan 2019, 13:56
Uspelo v prvem poskusu! :lol:
Hvala še enkrat!
S55DX
Prispevkov: 615
Re: FT8 v2
OdgovorNapisal/-a s55oo » 04 Apr 2019, 15:33
Zivjo!
Tudi fino malo pogledat. "RSGB 2018 Convention lecture - FT8 Secrets"
https://www.youtube.com/watch?v=smWp0TOEtlQ
Goran ANDRIC, S55OO
s55oo
Prispevkov: 261
Kraj: Domzale
