CIS DX QPSK63 Cotest
OdgovorNapisal/-a S51AY » 17 Sep 2010, 13:57
Dear Fellow PSK Contester,
The European PSK Club has the honour to invite radio amateurs from all over the world to participate in the CIS DX QPSK63 Contest 2010. The objective of the contest is to establish as many contacts as possible between radio amateurs around the world and radio amateurs in the Commonwealth of Independent States (http://en.wikipedia.org/wiki/Commonwealth_of_Independent_States) by using the QPSK63 mode. The Commonwealth of Independent States (CIS) is a regional organization whose participating countries are former Soviet Republics, formed during the breakup of the Soviet Union. Everybody can work everybody for QSO and multiplier credit. The 7th contest will be held from 12:00 UTC on 18.09.2010 to 12:00 UTC on 19.09.2010. The rules and other information can be found at the contest website (http://www.cisdx.srars.org/) . Second year it is strictly QPSK63 contest, no other modes are allowed. The maximum output power is 100 watts. Recommended frequencies are: 160 meters (1.838 – 1.840 MHz), 80 meters (3.582 – 3.590 MHz), 40 meters (7.040 – 7.050 MHz), 20 meters (14.072 – 14.080 MHz), 15 meters (21.072 – 21.080 MHz), and 10 meters (28.072 – 28.080 MHz). All the very best and see you all in the CIS DX QPSK63 Contest 2010!
CIS DX QPSK Contest Committee
Cabrillo QSO template
http://www.UT7FP.kiev.ua
Re: CIS DX QPSK63 Cotest
OdgovorNapisal/-a S51AY » 19 Sep 2010, 20:49
Pa je mimo en naporen contest... Aktivnost je bila nekoliko večja, kot lani, tako da ni bil dolgčas. V logu imam samo dve S5 postaji, S56B in S57AM. Še nekoga sem slišal/videl, ampak nekako si nisem zapomnil znakov (niti ni bila njihova frekvenca...).
Primerjava z lani; 200 QSO več, 74 množilcev več, MixW statistika pa kaže naslednje:
Rezultat pa najbrž ne bo držal, zgleda, da je neka napaka v "Stats" dll datoteki. Že lani mi je kazalo 728K točk, v uradnih rezultatih pa je 289K točk. Ampak to ni problem, saj organizatorji tako po "trgatvi" naredijo novi izračun.
OdgovorNapisal/-a s55oo » 19 Sep 2010, 21:11
Cestitke Arpi. Morda bi se napisal s kako tehniko si delal, PWR, etc..Morda se potem se kdo ojunaci. 73 GL!
Goran ANDRIC, S55OO
s55oo
Prispevkov: 261
Pridružen: 02 Avg 2001, 02:00
Kraj: Domzale
OdgovorNapisal/-a S51AY » 20 Sep 2010, 10:12
Glede moči sem pozabil napisati, da sem bil v kategoriji »SO-HP«, kot lani. Za izven CIS so samo 3 kategorije: SO-LP, SO-HP in MOST (HP); LP=10W, HP=100W. Glede uporabljene tehnike pa nič posebnega. Uporabljal sem običajno opremo, ki jo uporabljam za digimode :
RX/TX: FT-2000
Antene: ECO ASAY 3el. / 3 bander + INV V-ji
SW: MixW 2.18
Delal sem pa iz domače lokacije, pod hribom…
Nič drugega omembe vrednega. Postaja pač z CAT kontrolo, audio povezave pa direktno iz PKT konektorja na soundblaster. Ni se treba nič junačiti, le delati je treba. Kdor je zverziran za »vsakodnevno« PSK delo, ne bo imel težav. Začetnikom svetujem najprej kakšno PSK31 tekmovanje, da pridobijo rutino. PSK63 leti hitreje, kot 50 Baud RTTY, pa se je treba malo navaditi…
Drugo je pa operatorska tehnika, ki je tudi zelo pomembna. Treba je »izdelati« dobro tehniko pobiranja (skoraj polovico sem pobiral), izkoristiti vse možnosti postaje in programa, predvsem na sprejemu, pametno nastaviti makroje... Praktično enako, kot na RTTY. Ampak, to je že posebna tema. Če je kdo zainteresiran, lahko »udarimo« kakšno debato…
