Kontest ATV
Amaterska TV
Kontest ATV
OdgovorNapisal/-a s58ru » 27 Avg 2022, 14:57
Hi All
After talking to many of the participants, both in the UK and at Friedrichshafen, I have set out some proposed rule changes for future IARU ATV Contests. Not all need to be implemented, but I think that the time is right for change. I would welcome comment by e-mail to atv@iaru-r1.org before 30 October 2022.
Please circulate this document widely (and publish it?); it would be useful if someone was able to translate it into Italian and circulate it to the Italian ATV Community.
The ATV Contest community is strong, but I believe that these changes are required to continue to encourage newcomers. In brief the proposals are:
Only the bands 1.2cm and above qualify for increased scoring multipliers.
The contest is split into a low band ( 6m – 13cm?) contest in June and a high band (9cm – 0.2cm) contest in September)
Roving stations are limited to 2 locations except for bands of 1.2cm and higher.
Video codes sent to roving stations need not be changed for second contacts.
Equipment sharing between stations at a single site is stated as not being permitted.
Thanks
Dave, G8GKQ
IARU ATV Contest Coordinator
Pozdravljeni vsi skupaj
Po pogovoru s številnimi udeleženci, tako v Združenem kraljestvu kot v Friedrichshafnu, sem predstavil nekaj predlaganih sprememb pravil za prihodnja tekmovanja IARU ATV. Vseh ni treba izvajati, vendar mislim, da je pravi čas za spremembe. Vesel bi bil komentarja po e-pošti na atv@iaru-r1.org pred 30. oktobrom 2022.
Prosimo, da razširite ta dokument (in ga objavite?); koristno bi bilo, če bi ga kdo uspel prevesti v italijanščino in razposlati italijanski skupnosti ATV.
Skupnost ATV Contest je močna, vendar verjamem, da so te spremembe potrebne za nadaljnje spodbujanje novincev. Na kratko so predlogi:
Samo pasovi 1,2 cm in več so upravičeni do povečanih množiteljev točkovanja.
Tekmovanje je razdeljeno na tekmovanje v nizkem pasu (6 m – 13 cm?) v juniju in tekmovanje v visokem pasu (9 cm – 0,2 cm) v septembru)
Potujoče postaje so omejene na 2 lokaciji, razen za pasove 1,2 cm in višje.
Video kod, poslanih potujočim postajam, ni treba spreminjati za druge stike.
Navedeno je, da souporaba opreme med postajami na enem mestu ni dovoljena.
hvala
Dave, G8GKQ
Koordinator tekmovanja IARU ATV
20220826 IARU ATV Rule Change Discussion.pdf
(503.21 KiB) Prenešeno 600 krat
s58ru
Prispevkov: 1271
Pridružen: 28 Okt 2004, 22:07
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 18 Sep 2022, 12:59
IARU ATV tekmovanje
Rad bi začel z zgodovino mojih tekmovanj.
Po letu 2005, ko je ZRS ATV prepustil svoji usodi (formalno vedno obstaja vodja ATV), smo imeli velik problem, kam poslati naše IARU ATV Contest LOG-e. Smo kontaktirali več RA predstavnikov – IARU, kot zvez v LOG-ih. Ista težava pri sledenju rezultatov tekmovanja IARU ATV. Letos je prvo leto, ko nam je sporočil manager UKV (ne ATV manager) - v naši rubriki, rezultate tekmovanja IARU ATV 2022.
Moje pritožbe glede tekmovanja IARU ATV, sem jih tisočkrat pisno izrazil, a poslušalcev ni.
Datum
Ne vem, zakaj se je tekmovanje IARU ATV premaknilo s septembra na junij.
Tekmovanje ATV Ancona je imelo težave zaradi sovpadanja različnih tekmovanj v istem obdobju junija. RA ATV sodelujemo tudi v ostalih tekmovanjih.
Urnik
Vsa tekmovanja IARU imajo 24-urni urnik (od 14. ure v soboto do 14. ure v nedeljo). Tekmovanja v portablu, z gore, ne morete končati ob 20. uri.
Raporti
Novi sistem raportov je pozabil zvok. Na najnovejših ATV tekmovanjih zvočno poročilo ni podano - zvok se ne preverja.
Modulacije
Tekmovanje ne more združevati različnih modulacij. V sebi ima lahko vse modulacije a vsaka ima svojo razvrstitev. Skupne razvrstitve ni mogoče narediti, ker različne države nimajo enakih delovnih frekvenc. Digitalni sistem DVB-S, DVB-S2, DVB-T, DVB-T2 ima vsak svoje pod parametre ...
Rezultat
Za vsako modulacijo, rezultat, za vsako celoten QSO 4 točke ali 2 točki za ½ QSO, brez zvoka 3 točke ali 1 točka.
Za skupno razvrstitev se lahko seštejejo le točke udeležencev, držav, ki imajo isti Band Plan.
73 s58ru
(IARU ATV contest
Vorrei iniziare con la cronologia dei miei contest
Dopo il 2005, dopo che la ZRS ha lascato l’ATV al suo destino (formalmente ce sempre un ATV manager), avevamo il grande problema dove mandare i nostri LOG dei Contest IARU ATV. Abbiamo interpellato piu` RA – rappresentanti IARU che QSO nei LOG. Stesso problema per rintracciare i risultati dei Contest IARU ATV. Quest` anno e il primo anno che il UKV manager ( no il ATV manager ) ci ho comunicato –messo nella nostra rubrica risultati del contest IARU ATV 2022.
Le mie lamentele per il IARU ATV contest, le ho espresse per iscritto un migliaia di volte, ma non ci sono ascoltatori.
La data
Non so per quale motivo sì è spostato il contest IARU ATV, da settembre a giugno.
L’Ancona ATV contest ha avuto dei problemi per la coincidenza dei diversi contest nello stesso periodo di giugno. Noi RA ATV partecipiamo anche agli altri contest.
L’orario
Tutti i contest IARU hanno il orario di 24 ore ( dalle 14 di sabato alle 14 della domenica) Non si può finire un Contest in portatile da un monte alle 20 di sera.
Il rapporto
Il novo sistema di rapporto ha dimenticato l’audio. Negli ultimi ATV contest non si da il rapporto per l’audio – non si controlla l’audio.
Le modulazioni
Il contest non può unire diverse modulazioni. Può avere, nel suo interno, tute le modulazioni ma ognuno con la propria classifica. Non si può fare una classifica complessiva perche, i diversi stati non hanno le stesse frequenze di lavoro. Il sistema digitale DVB-S, DVB-S2, DVB-T, DVB-T2, ha ognuno i suoi sotto parametri …
Il punteggio
Per ogni classifica, il punteggio, per ogni QSO completo 4 punti o 2 punto per ½ QSO, senza audio 3 punti o 1 punto.
Per la classifica complessiva si possono sommare solo i punti dei partecipanti, degli stati, che anno lo stesso Band Plan.
73 s58ru)
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 18 Okt 2022, 09:18
1
Discussion Document – Possible IARU Region 1 ATV Contest Rule Changes
Introduction
I have participated in the IARU Region 1 ATV Contest for many years, and compiled the final
scores for the last 5 years.
I see the objectives of the contest to be to:
- To promote ATV activity, especially across international borders.
- To promote technical innovation within the ATV field.
- To encourage newcomers to participate in ATV activity.
The rules and scoring system need to support these objectives. I think that the current rules need
to be amended to continue to meet these objectives. Here are some proposals for discussion.
Technical Advances
When the existing rules were last amended, building ATV equipment for 23cm and above was
difficult and was rewarded by band multipliers to encourage technical innovation. With the current
availability of surplus mobile telephone base stations, microwave link equipment and Satellite TV
equipment, it is much easier to build an ATV station for the 23cm, 13cm, 9cm, 6cm and 3cm
bands. Additionally, commercially produced ATV equipment (the Icom IC-905) is soon to be
available for these bands.
Building equipment for the 1.2cm band is still reasonably difficult. The bands above this (0.6cm,
0.4cm and 0.2cm) are ripe for amateur technical innovation and band multipliers remain
appropriate.
My first proposal is that all bands 3cm and below should use the simple band multiplier of
2 points per km for 2-way and one point per km for one-way. 1.2cm should use 4 points per
km and bands above that should use 10 points per km (both halved for one-way).
Too Many Bands at Once?
With the recent addition of 50 MHz as an IARU Region 1 band, and the use of 0.2cm, the IARU
Region 1 ATV Contest covers 11 Bands. The level of complexity required to operate on more than
2 or 3 bands is well out of reach of beginners, and the transportation and set-up requirements for
portable operation are unreasonable.
Splitting the contest into a low-band and a high -band contest is one possible solution, with the
possible dates being the second weekend in June and the second weekend in September. The
low band contest could be in June, with the high band contest in September.
The band split could be 6m, 70cm and 23cm for low, and 13cm and above for high, or 13cm could
be included in the “low bands”.
My second proposal is that the contest be split into 2 weekends, a low band weekend in
June, and a high band weekend in September, with the split between bands to be decided
based on the feedback that I receive.
2
Roving Stations
In the current rules, roving (moving) to a new location allows you to contact new stations and also
stations that you have previously contacted and claim points for them (again). Whilst in a 2-day
contest it seems reasonable to use a different location on each day, some stations have been
gaining an advantage by “roving” to up to 6 locations during the contest. This disadvantages fixed
stations and beginners.
There is a case to be made for allowing multiple roving locations on the higher microwave bands
where it is difficult to establish line-of-sight paths with multiple other stations from a single location.
My third proposal is that entrants should be limited to 2 roving locations during the
contest, except for the bands 1.2cm and higher, where multiple roving locations would be
acceptable.
Video Codes for Contacts with Roving Stations
The current rules require that a station contacting a roving station for the second (or subsequent)
time changes his transmitted video 4-number code. This has proved difficult to achieve and even
more difficult to check during scoring. Given the low risk of (and low reward for) cheating, I do not
think that this rule is sensible.
My fourth proposal is that the requirement to change transmitted video code for second
and subsequent contacts with roving stations be dropped.
Shared Equipment
The current rules do not include any statements about the use of shared equipment by different
stations (callsigns/entries) at the same site. Taken to the limit, this could allow a queue of
operators using the same equipment to give multiple contacts (points) to a single remote station.
My fifth proposal is that each station operating at one site must use a unique set of
equipment and that equipment must not be shared with any other station operating from
the same site.
I would welcome comments on these proposed changes; nothing is decided yet, but I do feel that
some changes would benefit the hobby.
Please provide comment to me at atv@iaru-r1.org before 30 October.
Dave, G8GKQ. IARU Region 1 ATV Contest Coordinator.
26 August 2022
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 12 Apr 2023, 14:48
Hi All
A reminder to National Coordinators that the next IARU ATV Contest is in 8 weeks’ time on 10/11 June. I have attached a Word Document with a full text for publicity; please spread the word!
This will be my last year of coordinating the IARU ATV Contest. After 7 years, it is time for someone else to do it. Please could you let myself or Alex know if you are prepared to take on the task. I’ll be available to help for the first year.
Dave, G8GKQ
Opomnik nacionalnim koordinatorjem, da bo naslednje tekmovanje IARU ATV čez 8 tednov, 10. in 11. junija. Priložil sem Wordov dokument s celotnim besedilom za objavo; prosim razširite besedo!
To bo moje zadnje leto usklajevanja tekmovanja IARU ATV. Po 7 letih je čas, da to naredi nekdo drug. Prosim, če meni ali Alexu poveste, ali ste pripravljeni prevzeti nalogo. Prvo leto bom na voljo za pomoč.
Dave, G8GKQ
Koordinator tekmovanja IARU ATV ATV Contest Coordinator
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 29 Apr 2023, 13:06
Pozdravljen Dave G8GKQ!
Šele sedaj opažam, da si sedem let usklajeval IARU ATV tekmovanja.
Bi lahko opisal, kako se je to delo odvijalo pred teboj. Bi lahko naštel uspehe tvojega sedemletnega delovanja in kakšne so tvoje smernice za novega koordinatorja IARU ATV tekmovanja.
73 s58ru
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 08 Maj 2023, 08:40
Spoštovani, prilagam emai Italijanskega ARI menagerja ATV ( Italija ima šest zvez RA).
Emal je bil poslan vsem ATV-jašem, ne glede na pripadnost neki zvezi.
Pozdravljeni vsi ATV-jaši
Pred nekaj več kot mesecem dni sem vas želel spomniti, da bo naslednje "IARU Region 1 ATV Contest" potekalo od 12:00 UTC v soboto, 10. junija, do 18:00 UTC v nedeljo, 11. junija. Pravila so ostala nespremenjena v primerjavi z lanskim letom, saj bo treba morebitne spremembe odobriti na generalni konferenci regije 1 IARU oktobra 2023. (Eksperimentalna 6-metrska kategorija ni bila več predlagana)
Pravila za leto 2023 so na voljo na https://wiki.batc.org.uk/images/5/5c/20 ... _Rules.pdf. in vodnik o tem, kako sodelovati, je tudi na Wikiju na https://wiki.batc.org.uk/IARU_ATV_contest.
Sodelovanje je zelo preprosto, samo izmenjajte 4-mestno kodo z ustrezno postajo na videu. Koda mora biti poslana izključno prek videa, poročilo, sekvenco in lokator boste morali izmenjati tudi na druge načine (avdio na video, talkback itd.). Izbrati morate pravilno 4-mestno kodo, ne vse isto, kot je 2222, ali zaporedno, kot je 1234. Na primer, koda, kot je 2234, je OK. Za vsak uporabljen pas boste morali uporabiti drugo kodo.
Zahtevane podatke morate vnesti v preglednico, ki jo lahko prenesete tukaj: https://wiki.batc.org.uk/File:ATV-conte ... 230610.xls. Datoteko shranite v svoj računalnik tako, da spremenite ime datoteke tako, da vključuje vaš klicni znak. Nato ga odprite, omogočite makre (za izračun ocene) in izpolnite list s povzetkom. Nato zabeležite stike na kartico za vsak pas. Ne pozabite, da morajo biti razmerja večja od P2 za štetje točk – ne bi mogli videti številk, če bi bil samo P1. Shranite datoteko in preverite rezultate na zbirnem listu; nato ga pošljite po e-pošti svojemu državnemu koordinatorju (iw6atu@gmail.com) ali atv@iaru-r1.org.
Tekmovanje poteka na vseh pasovih od 432 MHz naprej. Vsi načini ATV so sprejemljivi v skladu z licenčnimi predpisi: DATV, FM ATV (uporabite svoj novi IC-905!). Prosimo, potrudite se sodelovati, tudi če ste vzpostavili samo eno povezavo. Vse to pomaga pokazati, da izkoriščamo bende.
Zgoraj mi je pred nekaj dnevi poslal mednarodni menedžer Dave, G8GKQ, da bi ga pozval k sodelovanju na naslednjem mednarodnem tekmovanju. Napisal je tudi, da bo zadnje leto, ko skrbi za tekmovanje in išče OM, ki bi ga lahko nadomestil ... pripelji ga !!!
Sledila bodo druga možna sporočila in tudi, če se vam bo zdelo koristno, videokonferenca kot v prejšnjih izdajah, da se opredelijo zadnje podrobnosti.
Kot vedno sem vam na voljo za vsa pojasnila, predloge in za vse, kar bi lahko koristilo stvari ATV!
73 od IW6ATU, Guido
Salve a tutti gli ATVisti,
a poco più di un mese volevo ricordare che il prossimo “IARU Region 1 ATV Contest” si svolgerà dalle 12:00 UTC di sabato 10 giugno alle 18:00 UTC di domenica 11 giugno. Le regole sono rimaste invariate rispetto allo scorso anno, poiché eventuali modifiche dovranno essere approvate alla Conferenza Generale della Regione 1 IARU nell'ottobre 2023. (Non è stata più proposta la categoria sperimentale dei 6 metri)
Le regole del 2023 possono essere trovate su https://wiki.batc.org.uk/images/5/5c/20 ... _Rules.pdf. ed una guida su come partecipare è anche su Wiki all'indirizzo https://wiki.batc.org.uk/IARU_ATV_contest.
Partecipare è semplicissimo, basta scambiare in video un codice di 4 cifre con la stazione corrispondente. Il codice deve essere inviato esclusivamente tramite video, dovrai anche scambiare il rapporto, il progressivo ed il locatore anche con altri mezzi (audio sul video, talkback, ecc.). Devi scegliere un codice a 4 cifre appropriato, non tutti uguali come 2222 o sequenziale come 1234. Ad esempio un codice come 2234 è OK. Dovrai usare di un codice diverso per ogni banda lavorata.
Devi inserire i dati richiesti nel foglio di calcolo che può essere scaricato da qui: https://wiki.batc.org.uk/File:ATV-conte ... 230610.xls . Salva il file sul tuo computer cambiando il nome del file per includere il tuo nominativo. Quindi aprilo, abilita le macro (per calcolare il punteggio) e compila la scheda riepilogativa. Quindi registra i contatti nella scheda per ogni banda. Ricorda che i rapporti devono essere superiori a P2 per conteggiare i punti: non saresti stato in grado di vedere i numeri se fosse solo un P1. Salvare il file e controllare i punteggi sulla scheda riepilogativa; quindi invialo via e-mail al coordinatore del tuo paese (iw6atu@gmail.com) o all'indirizzo atv@iaru-r1.org.
Il Contest si svolge su tutte le bande dai 432 MHz a salire. Tutte le modalità ATV sono accettabili entro i regolamenti della licenza: DATV, FM ATV (usa il tuo nuovo IC-905!). Si prega di fare uno sforzo per partecipare anche se si è realizzato un solo collegamento. Tutto aiuta a dimostrare che stiamo facendo uso delle bande.
Quanto scritto sopra è ciò che il manager internazionale, Dave, G8GKQ, mi ha inviato qualche giorno fa per sollecitare la partecipazione al prossimo contest internazionale. Ha anche scritto che sarà l'ultimo anno che si occupa del contest e cerca OM che lo possano sostituire...fatevi sotto!!!
Seguiranno altre eventuali comunicazioni ed anche, se lo ritenete utile, una videoconferenza come per le precedenti edizioni, per definire gli ultimi dettagli.
Come sempre sono a disposizione per eventuali chiarimenti, suggerimenti e per tutto quello che può essere utile alla causa dell' ATV!
73 de IW6ATU, Guido
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 07 Jun 2023, 08:22
Ciao Rudi eccomi:
Ik3HHG Jn65do
437 DVBS 200w 2 yagi x21 elementi pre’ 40db.
1290 DVBS 300w parabola diametro 2 mt pre’ 40db.
2321 DVBS 150w parabola diametro 2mt pre’ 38db.
5761 DVBS 40w disco 1mt pre’ 36db.
10369 DVBS 18w disco 1mt pre’ 38db.
SR 333
144750 fm verticale opp orizzontale
Grazie IK3HHG
Contest atv da casa e non portatile.
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a oe6rke » 08 Jun 2023, 19:27
Some stations from OE will be participating this contest.
Focus will be on Saturday for carinthia (OE8) focus to Soboth and Dobratsch and on Sunday in styria focus to Graz and Koralpe.
Because of local law regulations we will work 13cm and up with dvbs or dvbs2. Coordination will be done on local atv vhf qrg.
Looking forward to see you guys in the contest, 73 de oe6rke
oe6rke
Prispevkov: 37
Pridružen: 03 Apr 2006, 14:38
Kraj: Deutschlandsberg, Austrija
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 11 Jun 2023, 17:45
ATV IARU tekmovanje še ni končano.
Tukaj je “mrliška vežica”.
Morda, če ne bi spremenili datuma tekmovanja IARU ATV; morda, če bi spremenil čas tekmovanja; morda, če ne bi vmešali digitalnih načina ATV v tekmovanje; morda, bi bili rezultati, vsaj tukaj, sprejemljivi.
73 s58ru
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 13 Jun 2023, 10:14
Spoštovani IARU!
Dne 10./11.06. 2023 je bilo zadnje tekmovanje IARU ATV.
Ne bi želel, da bi tudi to tekmovanje minilo kot uspešno.
Spremembe pravil ATV tekmovanja v zadnjih letih nas vodijo v "prepad".
Raport »P«1/2/3/4/5 ni boljši od starega raporta »55C«. Nov raport je izgubilo "glas". Ne dovoli nam povemo, da ni bilo zvoka.
Contest ne more »mešati« FM, DVB-S, DVB-S2, DVB-T, DVB-T2…
Samo ena modulacija (DVB-S) ima preveč variant tudi za svoj samostojen contest.
Digitalni načini ne smejo sodelovati na tekmovanjih ATV.
Za enkrat je FM modulacija najbolj priljubljena - razširjena in najprimernejša za ATV tekmovanja.
Zelo zanimivo in razveseljivo je, da lahko ATV izvajamo tudi na frekvencah 50,70, 144, 432 MHz, vendar bi morale biti te frekvence izključene iz ATV tekmovanj. Izpustil bi tudi frekvenco 3,4 GHz, ker ta frekvenca v mnogih državah ni dovoljena.
73 s58ru
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 17 Jun 2023, 07:45
Pozdravljeni! AKOS
Smo skupina radioamaterjev, ki imamo licenco za ATV repetitor, ki je nameščen v Elerjih.
Repetitor sprejema in ponovno oddaja avdio in video signale v analognem načinu.
Vhodni frekvenci ATV repetitorja, ki uporabljamo sta 2350 MHz in 2390 MHz.
Zadnje tri mesece so se pričele pojavljati na teh frekvencah motnje. Motnje so ta mesec tako močne, da smo morali izklopiti RPT, ker je neuporaben. Motnje prihajajo iz smeri Kopra.
Moteči signal zavzema spekter, ki sega od 2320 do 2360 MHz. Intermodulaciski signali motijo tudi frekvence od 2380 do 2410 MHz. Moti tudi repetitorje v Italiji (do Vidma). Tudi na frekvenci 2320 MHz, ki se uporablja za ozkopasovne SSB prenose, so velike težave.
RA smo sekundarni uporabniki tega spektra a pri takih motnjah je lahko uporabnik samo eden.
Ni nam znano, da je ta frekvenca namenjena samo enemu uporabniku in to s takimi močmi.
13. Frekvenčni pas 2300 – 2450 MHz je namenjen tudi fiksni in mobilni storitvi na primarni podlagi ter radiolokacijski storitvi na sekundarni podlagi.
14. Frekvenčni pas 2400 – 2500 MHz (središčna frekvenca 2450 MHz) je določen za industrijsko, znanstveno in medicinsko uporabo. Storitve, razporejene v tem frekvenčnem pasu, se morajo sprijazniti s škodljivimi motnjami, ki jih utegne povzročiti omenjena uporaba.
Prilagam nekaj fotografij teh signalov, zaznanih na mojem domu ( JN65WM06PN) s spektralnim analizatorjem Rohde Schwarz.
Lahko vam posredujemo tudi fotografije Italijanskih RA.
S spoštovanjem
Rudi Pavlič (S58RU)
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 17 Jun 2023, 09:07
Spoštovani! AKOS
Med pripravo prijave o motnjah na 13 cm spektru, smo dobili informacije, da ste o motnjah seznanjeni, da ste naročili celo študijo o tem problemu.
Koper je manjše mesto kakor Trst in Videm. Tudi Trst in Videm ima slične uporabnike tega radijskega spektra a oni se ne pritožujejo nad svojimi uporabniki ampak nad »Koprskimi« uporabniki.
Si ne moremo zamišljati, da imajo sosedje boljšo – »čistejšo« tehnologijo za iste storitve kakor imajo naši operaterji.
Pozdrave
Rudi Pavlič S58RU
Prilagamo film o stanju nad Vojnikom in vašo študijo.
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 21 Jun 2023, 11:52
Spoštovani
V zvezi z vašima prijavama, z dne 16. in 17. 06. 2023, o radijskih motnjah, ki ste jih zaznali pri uporabi ATV repetitorja na vhodnih frekvencah 2350 MHz in 2390 MHz, vam sporočamo, da so v tem območju pričeli delovati oddajniki za javno mobilno telefonijo, ki so primarni uporabniki tega frekvenčnega spektra in so kot taki tudi ščiteni. Žal to niso motnje, ki bi jih bilo potrebno odpraviti ampak normalna uporaba primarnih uporabnikov frekvenčnega spektra.
V prijavi omenjate tudi, da ste izmerili intermodulacijske produkte. V zvezi s temi meritvami bi vas želeli opozorili, da se lahko ti generirajo tudi na uporabljenem spektralnem analizatorju. Podatkov o pogojih pri katerih ste opravili meritve nimamo zato le teh ne moremo komentirati. Vsekakor pa noben oddajnik ni idealen in ne oddaja samo v svojem kanalu ampak tudi izven. Jakosti signalov, ki jih lahko povzroča nek oddajnik izven kanala so določena v spektralnih maskah, ki so določene za posamezne tehnologije in so dostopne na spletu.
Iz zgoraj navedenega vzroka vaše prijave žal ne moremo obravnavati kot motnje zato bomo zadevo, ki jo v tej zvezi vodimo pod številko 06138-1/2023 zaključili.
Pri odgovoru se obvezno na številko zadeve 06138-1/2023
Lep pozdrav.
Miran Vozlič
Sektor za meritve in nadzor radiofrekvenčnega spektra
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 04 Okt 2023, 15:34
ATV
Sem na sprejemu na 144.750 MHz. To je povezovalna frekvenca za delo na ATV. V etru poteka ATV Ancona tekmovanje.
Na to tekmovanje smo se pripravljali od IARU ATV tekmovanju, ki je bilo v juniju. Še pred dnevi smo se menili, da bi šli tekmovat na Slavnika a tik pred zdajci smo se odločili, da ostanemo doma. Še več, odločil sem se, da ne bom sploh tekmoval.
Slovenci nimamo že dal časa svojega ATV tekmovanja. Pojavljamo se samo lahko na IARU ATV tekmovanjih.
Po letih životarjenja smo se ATV-jaši sestali na Vrhniki z ATV manažerjem pri ZRS. Po sestanku ugotavljamo, da po letu 2005, ko smo se sestali v Kopru, se naše število ni nič povečalo. Veliko RA ATV-jašev nas je zapustilo. Prej so RA ATV-jaši bili na severu in jugu Slovenije. Danes na severu so morda trije. Na jugu morda nekaj več. Vsekakor nas ni toliko in tako skupaj, da bi lahko imeli svoj samostojni ATV kontest.
Na IATU ATV tekmovanjih lahko smo konkurenčni, ker se povezujemo z sosednjimi državami.
Zadnje čase se je pojavilo veliko novosti od DVB-S, DVB-T, DVB-S2, ATV satelit. RA in denarja, ter verjetno tudi volje, je vedno manj.
K veliko zmešnjavo je pripomogel v veliki meri IARU. Na začetku se je popolnoma odtujil, pozneje pa je s svojimi napotki – direktivami uvedel še večjo zmešnjavo.
IARU je uvedel možnost dela s vsemi modulacijami, na vseh frekvencah tudi na tistih, ki so nam bile do sedaj onemogočene. Posledice, da je RA -QSO vedno manj a nobenemu ni za to mar.
Kaj so nam prinesle novosti? Nič! Le »zredčile« so naše vrste.
Kako naprej?
Verjetno, za nas, ki nas leta bašejo, ni bodočnosti.
Za RA in za ATV bo lahko kaj bodočnosti, če bodo se menjala vodstva zvez in IARU.
s58ru
Prispevkov: 1271
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 04 Okt 2023, 15:35
Moj pogled za ATV tekmovanja
ATV tekmovanja morajo biti čim bolj podobna ostalim VHF tekmovanjem.
Modulacija naj bo FM, ker druge modulacije niso primerne za tekmovanja. DVB-S, DVB-S2, DVB-T, DVB-T2, .. imajo lahko svoja tekmovanja.
Frekvence naj ostanejo samo tiste, ki so skupne vsem državam.
Ura naj bo standardna, od sobote od 14. ure do nedelje do 13.59. Če je urnik pretesen, ga lahko podvojite s 24 na 48 ur ali pa organizirate več tekmovanj v enem letu.
Tekmovanje IARU se bi moralo spet vrniti v september. V juniju je na vrsti že kar nekaj zahtevnih tekmovanj na VHF.
RA, ki se ukvarjajo tudi z ATV, se "držijo" okoli svojega ATV RPT. RPT so »lepilo«, ki nas združuje in nam omogoča preživetje – preživljanje.
s58ru
Prispevkov: 1271
Vrni se na ATV
