Contest IARU ATV
Amaterska TV
Contest IARU ATV
OdgovorNapisal/-a s58ru » 21 Maj 2020, 07:41
1200 UTC 13. junij - 1800 UTC 14. junij - IARU International ATV Contest
https://www.iaru-r1.org/wp-content/uplo ... -rules.pdf
s58ru
Prispevkov: 1224
Pridružen: 28 Okt 2004, 21:07
Re: Contest IARU ATV
Ciao tutti
Sarò in jn65aw monte Cesen Treviso quota 1500mt in compagnia di Ik3ghy Giorgio dal sabato fino la domenica .
Attrezzatura : 144750 fm 144390ssb yagi 5 elementi H
23cm 100w 55el fm
13cm 80w disco diametro 1mt fm
6 cm 8w disco 1 mt offset fm
3cm 5 w disco 1mt offset fm
1,2cm 1w disco 0,6 mt procom fm
23cm 2w dvb-t
13cm 5w dvb-t
Tutto rtx
73 Ik3hhg frank
s58ru
Prispevkov: 1224
OdgovorNapisal/-a s58ru » 21 Maj 2020, 14:24
Letošnji naslov za pošiljanje LOG-ov za contest IARU ATV je atv@iaru-r1.org .
s58ru
Prispevkov: 1224
OdgovorNapisal/-a s58ru » 21 Maj 2020, 18:42
s58ru
Prispevkov: 1224
OdgovorNapisal/-a s58ru » 23 Maj 2020, 18:18
Dave G8GKQ <dave.g8gkq@gmail.com>
18:29 (pred 39 minutami)
Za Alex, f6aqo, hb9drs, vhf, m.cziba, ea7ka, sm0ofv, bpaloma, f5ago, microwave, Francesco, Contests, DF3EI, TRANS, Hans, clive, Chris, Jacques
The IARU Region 1 ATV Contest will go ahead on the weekend of 13/14 June. However, due the COVID-19 crisis not all participants will be able to reach their portable sites, and some may feel that they are at a disadvantage in only being able to operate from home due to National restrictions.
To address these concerns, the contest will be run with 2 sections:
Section 1 will be for participants operating from their registered home QTH. No change of operating location will be permitted during the contest for entries in this Section.
Section 2 will be for participants operating away from their registered home QTH at any time during the contest. So, even if you operate from home on one day and a portable location on the second day, if you want to add the scores under the rover rule, you must enter Section 2.
Please use the normal entry spreadsheet https://wiki.batc.org.uk/images/d/d5/AT ... 190608.xls and state in the address box whether you are entering Section 1 or Section 2. The latest spreadsheet has a drop-down box for this selection.
Apart from this change, the normal rules will apply. These can be found at http://www.iaru-r1.org/wp-content/uploa ... -rules.pdf
Entries should be submitted to your National Coordinator and then passed to me. I will accept entries direct on the e-mail address atv@iaru-r1.org if you are unable to contact your national coordinator.
Please pass this e-mail on to any prospective participants – just for 2 days, we need to get people off of QO-100 and onto the other bands!
Dave, G8GKQ, IARU Region 1 ATV Contest Coordinator.
18:29 (pred 33 minutami)
Za Alex, f6aqo, hb9drs, vhf, m.cziba, ea7ka, sm0ofv, bpaloma, f5ago, mikrovalovna pečica, Francesco, tekmovanja, DF3EI, TRANS, Hans, clive, Chris, Jacques
Natečaj ATV za regijo IARU se bo nadaljeval konec tedna 13. in 14. junija. Vendar zaradi krize COVID-19 vsi udeleženci ne bodo mogli priti do svojih prenosnih mest, nekateri pa se lahko počutijo, da so v slabšem položaju, če lahko zaradi nacionalnih omejitev poslujejo od doma.
Natečaj bo potekal v dveh sklopih:
1. del bo namenjen udeležencem, ki delujejo od svojega registriranega doma QTH. Med natečajem za prijave v tem razdelku ne bo dovoljena nobena sprememba lokacije poslovanja.
Oddelek 2 bo namenjen udeležencem, ki kadarkoli med tekmovanjem delujejo zunaj svojega registriranega doma QTH. Tudi če en dan upravljate od doma in drugi dan na prenosni lokaciji, če želite rezultate dodati po pravilih roverja, morate vnesti oddelek 2.
Prosimo, uporabite običajno vnosno preglednico https://wiki.batc.org.uk/images/d/d5/AT ... 190608.xls in v naslovnem polju navedite, ali vnašate 1. ali 2. odstavek. Najnovejša razpredelnica vsebuje spustno polje za ta izbor.
Razen te spremembe bodo veljala običajna pravila. Te najdete na http://www.iaru-r1.org/wp-content/uploa ... -rules.pdf
Prijave je treba predložiti nacionalnemu koordinatorju in jih nato posredovati meni. Prijave sprejemam neposredno na e-poštni naslov atv@iaru-r1.org, če se ne morete obrniti na svojega nacionalnega koordinatorja.
Prosimo, da to e-pošto posredujete vsem bodočim udeležencem - samo za dva dni moramo ljudi iz QO-100 spraviti na druge skupine!
Dave, G8GKQ, koordinator tekmovanja ATV za regijo IARU 1.
s58ru
Prispevkov: 1224
OdgovorNapisal/-a oe6rke » 02 Jun 2020, 09:47
anyone else planing being active in this contest? Would be nice to allign activities :)
i plan being active from jn76mu at 1800msl bearing east west.
Maybe we could agree using this new tool to announce activities: https://dxspot.batc.org.uk/
br Robert, 73 de oe6rke
oe6rke
Prispevkov: 37
Pridružen: 03 Apr 2006, 13:38
Kraj: Deutschlandsberg, Austrija
OdgovorNapisal/-a s58ru » 11 Jun 2021, 14:02
1200 UTC 12. junij - 1800 UTC 13. junij 2021- IARU International ATV Contest
s58ru
Prispevkov: 1224
Vrni se na ATV
