Danes je 06 Jun 2020, 00:35
 Naslov prispevka: Contest ATV 2017
OdgovorObjavljeno: 22 Mar 2017, 14:08
Pridružen: 28 Okt 2004, 21:07
Prispevkov: 697
-------- Forwarded Message --------
Subject: [Predsedniki] Request to publish information in your HAM magazine about the IARU ATV contest that will be held the second full weekend in June
Date: Wed, 22 Mar 2017 08:26:47 +0100
Reply-To: Predsedniki radioklubov ZRS <predsedniki@hq.zrs.si>
To: predsedniki@hq.zrs.si
CC: uozrs@googlegroups.com
Posredujte naprej svojim zainteresiranim članov, ki se ukvarjajo z ATV jem
Predsednik
Bojan Majhenič - S52ME
Zveza radioamaterjev Slovenije
Bezjakova ulica 151, Pekre
SI - 2341 Limbuš
Republika Slovenija
Mobil: +386 (0) 041 781 949
On tor., mar. 21, 2017 at 23:11, s51fb@slovhf.net
<s51fb@slovhf.net> wrote:
Dear Chris
Thanks for remainder.
Done https://slovhf.net/ (sorry, written in Slovenian language).
Kind regards
Miha, ON/S51FB
ZRS VHF Manager
, je PA3CRX napisal
> Gentleman,
> Herewith I would like to ask you to publish information about the
> IARU ATV contest that will be held from 10 June 12:00 UTC to 11 June
> from 18:00 UTC. So enough time to schedule and make that ATV contact
> or to go portable.
> In fact, most operators do not really consider it as a contest but as
> an 'activity weekend', many ATV operators are present in several
> countries, some portable.
> However, many countries do not publish this activity in their HAM
> magazine, so a lost opportunity to have (and show) activity on the
> higher bands. Therefore I send this request now, so you have enough
> time to get it in your national HAM magazine.
> However; then you must take action!
> If you are not able to do it yourself: please find someone that could
> do it!
> Last year, some stations from Sweden joined with only one contact to
> place ATV on the map in their country (and afterwards they published
> an article in the HAM magazine). Spain promised to join this year. So
> pay attention to this activity and show we need to keep these bands
> that are under pressure.
> Please see for the report of 2016:
> https://www.iaru-r1.org/images/VHF/news ... ter_70.pdf [1]
> Please see the links below for information about the rules and the
> easy Excel logsheet (no difficult installation or so). If you do not
> have a local ATV or contest manager that would like to take care about
> the results, no problem, the logs could be send to the email address
> that is mentioned in the logsheet.
> [next line not to be published but for your own information: If you
> would like to (partly) translate the logsheet or would like to change
> the email address: someone with Excel experience could do this. Do not
> change location of cells and make sure the fields are protected again
> before you distribute it locally].
> English version rules (can also be found in the VHF managers
> handbook):
> https://www.iaru-r1.org/images/VHF/atv/ ... n_2015.pdf
> [2]
> English version logsheet:
> https://www.iaru-r1.org/images/VHF/atv/ ... YYMMDD.xls
> [3]
> Dutch version rules:
> https://vhf-uhf.veron.nl/wp-content/upl ... e-2017.pdf
> [4]
> Dutch version logsheet:
> https://vhf-uhf.veron.nl/wp-content/upl ... JJMMDD.xls
> [5]
> Thanks for your cooperation,
> Chris van den Berg IARU ATV contest manager
> Links:
> [1] https://www.iaru-r1.org/images/VHF/news ... ter_70.pdf
> [2]
> [3]
> [4]
> [5]
> _______________________________________________
> Iaru_c5 mailing list
> Iaru_c5@ml.oevsv.at
> http://ml.oevsv.at/listinfo/iaru_c5
Attached Message Part
Predsedniki mailing list
Predsedniki@hq.zrs.si
http://hq.zrs.si/listinfo.cgi/predsedniki-zrs.si
 Naslov prispevka: Re: Contest ATV 2017
OdgovorObjavljeno: 20 Maj 2018, 11:21
Prispevkov: 697
http://arifidenza.it/Forum/topic.asp?TOPIC_ID=331421
OdgovorObjavljeno: 04 Jul 2018, 16:49
Prispevkov: 697
International Amateur Radio Union
Region 1
VHF - UHF - µW Newsletter
Edition 77
29 May 2018
Jacques Verleijen, ON4AVJ
ATV Contest
The annual IARU International Amateur TV Contest will be held from 1200 UTC on Saturday 9 June until 1800 UTC on Sunday 10 June. ATV contacts on all amateur bands above 432 MHz are valid. To participate in the contest, ATV stations simply need to exchange a 4-number code by video and then exchange reports and locators by voice. Logs should be submitted to your National ATV contest manager, who will compile the National rankings and then pass the logs to me to compile the international rankings. Certificates will be awarded to the highest scoring station overall and the highest scoring station in each band Different 4-number codes should be used for each band: • If a station changes location it should restart its serial numbers from 1, and change all its codes; • If that station then works another station that he worked from his previous location, it should ask them to send a different code as well. • A separate set of logs should be submitted for each new location. Logs should be submitted using the Excel template that can be found here: https://www.iaru-r1.org/images/VHF/atv/ ... YYMMDD.xls National Contest Managers are encouraged to help competitors to fill in this form – we should not exclude anyone from the contest just because they can’t do Excel!! The ATV Contest rules are here: https://www.iaru-r1.org/images/VHF/atv/ ... n_2015.pdf
Key ATV dates: • 9/10 June: ATV Contest • 25 June: Deadline for submission of Logs to National Contest Manager • 16 July: National Contest Manager to submit all logs to International Contest Manager email: IARU_ATV@uba.be • 6 August: International Contest Manager to publish International Results
