Contest ATV 2016
Amaterska TV
Contest ATV 2016
OdgovorNapisal/-a s58ru » 05 Jan 2016, 15:48
Contest IARU reg. 1 ATV bo 11.06.2016 od 12:00 do 12.06.2016 do
18:00 po GMT.
Ancona contest
Letos bo ATV Ancona contest 11.09. 2016 od 8:00 do 18:00 po GMT.
s58ru
Prispevkov: 1266
Pridružen: 28 Okt 2004, 22:07
Re: Contest ATV 2016
OdgovorNapisal/-a s58ru » 05 Maj 2016, 12:02
Gentlemen,
As far as I have seen them, in most of your magazines I did not notice any attention for the IARU ATV contest.
In several countries there is a lot of ATV activity but even when just one contact is made, it would be appreciated to receive a log. No fancy log-installation or so, just open the excel sheet, fill out some fields, save it and send it to the mentioned email address.
The rules and logsheet are on the IARU website but a bit hard to find, therefore I give you the link: http://www.iaru-r1.org/index.php/vhfuhs ... 8-atv-news
Results from last year: http://www.iaru-r1.org/index.php/vhfuhsshf/1455-atv
If you do not have an ATV station but you have SDRsharp running with (for example) an RTLstick: you can easily receive ATV signals in the 70 cm and 23 cm band by using TVsharp. No additional installation, just run TVsharp.exe instead of SDRsharp.exe. (It is AM but you can detect FM with it). Link for direct download of TVsharp: http://pi6ats.nl/tv.zip
Hopefully you could pay attention to it on your website and/or local infrastructure.
ATV could stimulate activity and interest in frequencies VHF-and-above so lets give it a try!
Best regards,
s58ru
Prispevkov: 1266
OdgovorNapisal/-a s58ru » 30 Maj 2016, 05:35
Ciao tutti
IK3HHG/3 jn65aw quota 1500mt slm sarò attivo con 4 bande
23cm antenna 55el 80w
13cm disco 1mt 80w
6cm disco 80cm offset 8w
3cm disco 80cm offset 3,5w
sabato&domenica vi aspetto in atv analogica dai che ci divertiamo
tele73 ik3hhg frank
s58ru
Prispevkov: 1266
OdgovorNapisal/-a s58ru » 02 Jun 2016, 22:16
Ciao Chris PA3CRX
Ti scrivo in Italiano, perche la traduzione dallo Sloveno non sarebbe capibile. Poi io non so l’Inglese.
Stavo pensando alla data del contest ATV.
In settembre il contest ATV era dopo il contest IARU 144 MHz ciò e`dopo un contest di solo una frequenza.
Adesso alla fine di maggio ce il WPX. Dopo una settimana ce il contest di giugno che spazia, da 144 MHz a 241 GHz. Dopo una settimana ce il contest ATV.
I RA che lavorano i contest SSB nelle frequenze più alte lavorano anche in ATV.
Questo per la data.
Sono sicuro che la IARU debba cambiare anche l’orario e il regolamento del contest ATV.
Senza questi cambiamenti non ci sarà nessun passo avanti.
Questo regolamento è un incentivo a non far il contest, da farlo da casa in pantofole, da mandare il log solo per burla.
73 s58ru
s58ru
Prispevkov: 1266
OdgovorNapisal/-a s58ru » 04 Jul 2016, 23:26
Gentlemen,
In the contest rules is mentioned
“Responsibility National ATV manager, VHF manager or the National Contest Committee: judge logs in time, send the results within four weeks after the contest to the IARU ATV manager.”
This is the fourth week so I like to start with the results next week.
Not to push you but to prevent misunderstandings.
All received logs will be confirmed. (The sooner I receive the logs, the sooner the results will be ready).
A ‘log reader’ will be used to compare and to generate the final results.
Best regards,
Chris PA3CRX
s58ru
Prispevkov: 1266
OdgovorNapisal/-a s58ru » 19 Jul 2016, 16:01
IARU-ATV-results-2016.pdf
(74.9 KiB) Prenešeno 740 krat
s58ru
Prispevkov: 1266
OdgovorNapisal/-a s58ru » 07 Avg 2016, 22:59
s58ru
Prispevkov: 1266
Vrni se na ATV
