ballon z kamera ob prvi septembra
Amaterska TV
OdgovorNapisal/-a oe6rke » 28 Avg 2012, 14:16
Ahoij, dragi OM,
on saturday the 1st september will be a special event to celebrate 100 years discovery of height radiation (at bead weather it will be postboned to sunday the 2nd).
therefor a baloon with atv equipment is started directly from graz. Launch time will be around 10:00 am and the signal will be transmitted at 2430 Mhz F3E analogue. We expect a flight route from graz towards muska sobota.
we try to receive the signal direct and via relais back to the audiance in graz schlossberg.
It would be great opportunity and help if someone could pick up the signal at 2430 Mhz F3E analogue too and retransmitt it to the repeaters nearby.
So far on following repeaters we will look for a signal:
D-ATV Schöckl, D-ATV Dobl, D-ATV Wolfgangi, ATV Khunegg and if works out D-ATV Pohorje too.
The baloon and the vesel will have an aprs beacon at 144,930 MHz (feel free to igate if you want to).
hvala za pomoc in demonstracije nas super hobbie to javno!
lp Robert, 73 de oe6rke
vec informacije: http://www.hephy.at/physik/die-kosmische-strahlung/
oe6rke
Prispevkov: 37
Pridružen: 03 Apr 2006, 13:38
Kraj: Deutschlandsberg, Austrija
Re: ballon z kamera ob prvi septembra
OdgovorNapisal/-a s53zo » 29 Avg 2012, 19:02
Robert,
dosti sreče z balonom, upam da vam uspe.
V Murski Soboti bom vzpostavil začasni igate na 144.930, da vam pomagam slediti pozicijo.
Simon, S53ZO
s53zo
Prispevkov: 208
Pridružen: 21 Maj 2001, 01:00
Kraj: Murska Sobota
OdgovorNapisal/-a oe6rke » 30 Avg 2012, 22:10
Hvala Simon,
ballon 1 jutri bo call OE0S-1 in ballon dve on sobota call OE0S-2.
start čas petek: 8:30 to 9:30
start čas sobota: 10:30 to 11:30
oe6rke
Prispevkov: 37
Vrni se na ATV
Po forumu brska: 0 registriranih uporabnikov in 29 gostov
