Kontest ATV
Amaterska TV
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 24 Maj 2024, 11:05
Tekmovanje IARU ATV da, tekmovanje IARU ATV ne?
Mislim, da to ni dilema. Morda je dilema med tem, ali narediti nekaj QSO ali v celoti ignorirati tekmovanje IARU ATV.
Za IARU je ATV Pepelka.
Po letu 2005, letu bolj ali manj, gre ATV na "podstrešje". Od časa do časa se pokaže v kakšni novi "preobleki" DVB-S, DVB-T, satelit, ...
Končni udarec ATV je zadal IARU. IARU, ki bi moral pomagati, spodbujati in usmerjati, je vnesel kaos in spodbuja opuščanje RA ATV.
Še nikoli nisem slišal, da bi gospodinja na tržnici prosila, daj temi zelenjave.
IARU ne dela razlike med FM, DVB-S2, ... vse je "juha". In ustanovili so komisijo strokovnjakov. (Mislim, da ti strokovnjaki še nikoli niso sodelovali na ATV tekmovanju .)
V pravilih tekmovanja IARU ATV med drugim piše:
Vodja tekmovanja IARU ATV: Organizirajte in objavite prazno datoteko dnevnika vsaj 3 tedne pred tekmovanjem, sodnik prijavite se pravočasno in rezultate objavite v šestih tednih po tekmovanju.
“IARU ATV contest manager: Organize, and publish blank log file at least 3 weeks before the contest, judge logs in time, and issue results within six weeks after the contest.”
Na straneh društev sploh ni pravil, tudi v angleščini ne...
88 s58ru
s58ru
Prispevkov: 1266
Pridružen: 28 Okt 2004, 22:07
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 24 Maj 2024, 14:39
Hi Rudy
The updated Contest Rules have been published on the IARU Website for some weeks:
https://www.iaru-r1.org/about-us/commit ... ontesting/
The rules are here:
https://www.iaru-r1.org/wp-content/uplo ... ontest.pdf
and the spreadsheet is here:
https://www.iaru-r1.org/wp-content/uplo ... 4-4-21.xls
The rules were amended this year following a request for comment (which I sent to you) and discussions amongst contest participants at the last IARU Region 1 conference.
All ATV modes (FM, AM, DVB-S/S2, DVB-T/T2) are allowed in the contest. Satellite is excluded, but there are some proposals for a separate satellite event under discussion.
I have copied this e-mail to Rob PE1ITR who is taking over running the contest this year.
Look forward to seeing you in the list of entrants for this year.
s58ru
Prispevkov: 1266
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 08 Jun 2024, 09:17
Nered, vreden IARU.
Danes bodo na dan prišli vsi ATV čudeži.
s58ru
Prispevkov: 1266
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 08 Jun 2024, 12:42
https://slovhf.net/iaru-r1-atv-2024-tekmovanje/
Komu je namenjeno to vabilo?
Že v letu 2005 je bila Slovenija razdeljena na tri dele. Nekaj ATV-jašev je bilo na severu od Celja. Nekaj jih je bilo južno od Postojne. Osrednja Slovenija je bila siva cona ATV.
Takrat smo imeli ATV managerja pri zvezi; enkrat letno srečanje na Trojanah; vsaj na papirju 15-20 repetitorjev; ATV Slovenski kontekst; IARU ATV kontekst;…
Danes, ATV manager je v »oblakih«; lahko se udeležujemo le na IARU kontekstih; imamo dva ATV RPT; v Sloveniji skoraj nimamo korespondentov; na Hrvaškem verjetno ni ATV-jašev; v sosednji Italiji vlada IARU- kaos.
Danes niso samo volitve v Evropski Parlament. Danes se bo videlo koliko je uspešen IARU in posredno razne zveze RA.
s58ru
Prispevkov: 1266
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 04 Jul 2024, 20:04
Pozdravljen Rob PE1ITR!
8 in 9 junija naj bi se odvijalo IARU ATV tekmovanje.
Datum je mimo a o tekmovanju ne duha ne sluha. V času tekmovanju sem bil na poslušanju na povezovalni frekvenci 144.750 MHz in nisem slišal - zasledil noben QSO.
Bi lahko predali kakšno poročilo o misterioznem IARU ATV tekmovanju 2024?
Dave G8GKQ je uspel kot predstavnik IARU, uvest razdor in kaos s še tako majhni populaciji ATV – jašel. Ti si prevzel njegovo funkcijo v sklopu IARU, ne da bi se predstavil, se seznanil z vsemi našimi pritožbami in probal nam predstavit tvojo politiko – smernice za ta naš zanemarjen ATV hobi?
73 s58ru
s58ru
Prispevkov: 1266
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 05 Jul 2024, 14:50
Robert Kiendl
ordetsSnopg924l058ugg93
h
c0c78l5
681it35
2
t96tl061h0006fl0c944
Ali se kdo od nas namerava udeležiti tekmovanja Tri-Veneto ATV naslednjo nedeljo (14.7.2024)? To bi bila dobra priložnost za analogni in tudi digitalni štirikolesnik.
https://www.ari.it/contest-vhf-up/altri/8092.html
s58ru
Prispevkov: 1266
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 17 Maj 2026, 13:09
https://www.ari.it/en/contest-vhf-up.html ATV
Manager Banda Data Giugno Orario (UTC)
IZ1GCV 432-up 06-07 Trofei UHF e Sup Contest Canavese
14:00-14:00
IARU 50-up 06-07 Contest IARU ATV Reg. 1
12:00-18:00
https://wiki.batc.org.uk/IARU_ATV_contest
The IARU Region 1 ATV Contest will go ahead on the weekend of 13 June 2026 from 1200UTC to 14 June 2026 1800UTC. In the UK there will be a 3 sections, one for single location stations, one for roving (multiple location) stations and a UK Only 2M stations.
Please use the entry spreadsheet here: Entry Spreadsheet
The normal rules can be found at IARU ATV Contest Rules.
Entries should be submitted to your National Coordinator (Clive G3GJA in the UK at contests@batc.tv). Rob, PE1ITR will accept entries direct on the e-mail address atv@iaru-r1.org if you are unable to contact your national coordinator.
Please pass this on to any prospective participants – just for 2 days, we need to get people off of QO-100 and onto the other bands!
Tekmovanje IARU Region 1 ATV bo potekalo konec tedna, 13. junija 2026, od 12:00 UTC do 14. junija 2026 ob 18:00 UTC. V Združenem kraljestvu bodo trije oddelki: eden za postaje z eno lokacijo, eden za potujoče postaje (z več lokacijami) in eden za postaje 2M samo v Združenem kraljestvu. Prosimo, uporabite preglednico za prijavo tukaj: Preglednica za prijavo Običajna pravila najdete v Pravilih tekmovanja IARU ATV. Prijave je treba oddati vašemu nacionalnemu koordinatorju (Clive G3GJA v Združenem kraljestvu na contests@batc.tv). Rob, PE1ITR, bo sprejemal prijave neposredno na e-poštni naslov atv@iaru-r1.org, če ne morete stopiti v stik z vašim nacionalnim koordinatorjem. Prosimo, da to sporočite vsem potencialnim udeležencem – samo za 2 dni moramo ljudi spraviti s QO-100 na druge pasove!
s58ru
Prispevkov: 1266
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 21 Maj 2026, 16:20
s58ru
Prispevkov: 1266
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 18 Jul 2026, 10:42
Danes, ko sem raziskoval tekmovanja, sem videl te podatke za VHF tekmovanja:
Svetovno VHF tekmovanje CQ 2026
SSB/CW/FM: 4.-5. julij
Digitalno: 18.-19. julij
Začetek: sobota 14:00 UTC
Konec: nedelja 14:00 UTC
Bi bilo "kriminalno", če bi to shemo kopirali za tekmovanja ATV?
s58ru
Prispevkov: 1266
Re: Kontest ATV
OdgovorNapisal/-a s58ru » 19 Avg 2026, 12:10
IK3HHG
Salve a tutti,
il giorno 13/09/2026 ore gmt 07:00-15:00 siamo operativi dal monte Cesen jn65aw per il contest atv Ancona solo in modalità analogico con il nominativo IZ3PWF poi due aiutanti scarsi ik3ghy, ik3hhg
Setup: 23cm disco 1,90mt tx100w; 13cm disco 1,90mt tx100w,
trv 6cm disco 1mt tx2w; trv 3cm disco 1mt tx4,5w
frequenza di chiamata fm 144750mhz V
73 PS fattevi belli
Pozdravljeni vsi,
13. septembra 2026, od 7:00 do 15:00 GMT, bomo delovali iz Monte Cesena, JN65AW, za tekmovanje Ancona ATV. Uporabljali bomo samo analogni način s klicnim znakom IZ3PWF, skupaj z dvema slabima pomočnikoma, IK3GHY in IK3HHG.
Nastavitev: 23 cm antena, 1,90 m, 100 W oddajnik-sprejemnik; 13 cm antena, 1,90 m, 100 W oddajnik-sprejemnik;
6 cm antena, 1 m, 2 W oddajnik-sprejemnik; 3 cm antena, 1 m, 4,5 W oddajnik-sprejemnik.
FM klicna frekvenca: 144750MHz V
73 PS: Polepšajte se.
s58ru
Prispevkov: 1266
Vrni se na ATV
