YAESU vx-6R
Moderator: S57NML
YAESU vx-6R
OdgovorNapisal/-a S54NT » 23 Feb 2010, 10:15
Pozdravljeni.
Zanima me, če kdo ve, kako se pripravi ročno postajo YAESU VX-6R do tega, da oddaja na 2 m območju, sprejema pa na 70 cm ?
Lep pozdrav in 73 de S54NT
S54NT
Prispevkov: 59
Pridružen: 22 Mar 2006, 10:13
Kraj: Idrija
Re: YAESU vx-6R
OdgovorNapisal/-a s50ml » 23 Feb 2010, 11:00
izsek iz navodila na strani 34:
Storing Independent Transmit Frequencies (“Odd Splits”)
All memories can store an independent transmit frequency, for operation on repeaters with
non-standard shift. To do this:
1. Store the receive frequency (downlink) using the method already described under
MEMORY STORAGE (it doesn’t matter if a repeater offset is active).
2. Turn to the desired transmit (uplink) frequency, then press and hold in the [F/W] key
for one second.
3. Within five seconds of releasing the [F/W] key, rotate the DIAL knob to select the
same memory channel number as used in step “1” above.
Upam da pomaga.
LP Matjaž
s50ml
Prispevkov: 11
Pridružen: 03 Apr 2007, 00:18
Re: YAESU vx-6R
OdgovorNapisal/-a S54NT » 24 Feb 2010, 09:30
Žvijo.
Hvala za pomoč. Zadeva deluje tako kot je treba. Očitno sem spet user manual premalo pozorno prebral...kot vedno :oops: .
73 DE S54NT, ANDREJ
S54NT
Prispevkov: 59
Kraj: Idrija
Vrni se na Sateliti
