SuitSat Readies for Operation on 145.990 MHz
Moderator: S57NML
OdgovorNapisal/-a S56CT » 28 Nov 2005, 11:09
Now is the time to begin preparing your amateur radio station to receive signals from SuitSat, the most unusual Amateur Radio satellite ever orbited. SuitSat amateur radio equipment will be installed inside a surplus Russian Orlan spacesuit. It will become an independently orbiting satellite once it is deployed by the crew of the International Space Station during an extravehicular activity, tentatively planned around December 8, 2005.
Running only on internal batteries within the spacesuit, SuitSat will have a limited, but interesting lifetime beaming down special messages and an SSTV image as it floats in space. Having no external thrust to adjust its orbit after it is hand-deployed during the EVA, SuitSat will be in a free-floating, but decaying orbit around Earth. It is expected to remain in orbit up to 6 weeks after being deployed.
The image on the left shows SuitSat in it's flight configuration. You can see the electronics control panel on the top of the helmet along with the SuitSat antenna. A new handle has been added around the midsection of the suit (black stripes). The handle is an important addition that will allow the astro/cosmonaut launching the suit to move it safely. [Photo credit to Steve Bible N7HPR - Thanks Steve!]
SuitSat's transmissions will include special international voice messages, spacesuit telemetry, and a pre-programmed SSTV picture on its 145.990 MHz FM downlink. If you have already received the packet station or heard the ISS crew on 2-meter voice, then you already have most of what you need. Amateur radio signals from the ISS can be received with a 2 meter vertical antenna so an elaborate tracking system is not necessary. The SSTV signal can be decoded with personal computer SSTV software after you connect your computer to the speaker output of your radio.
See the complete article including additional SuitSat photographs at:
http://www.amsat.org/amsat-new/articles/SuitSat/
Also see the article "This Is SuitSat-1 RS0RS" by Frank Bauer,KA3HDO at:
http://www.amsat.org/amsat-new/articles ... /index.php
OdgovorNapisal/-a S56CT » 02 Feb 2006, 15:28
Our group,SSPBD have a receive downlink of the LEO satellites (SO50,AO51,SO50 and ISS) to Echolink nodes va3sf-r and ve3oc-r.
We will also be tracking SUITSAT when it is transmitting over North
America and will downlink its signals. ( Voice recording or SSTV
signals )
There is also a voice announcment on the nodes prior to the passes to
advise of which satellite is being tracked.
If you have any questions, you can email me offline at va3sf@...
73 and good luck
Steve VA3SF
http://www.va3sf.com
Prenešeno iz yahoo.groups.com
73, Tilen
OdgovorNapisal/-a s55m » 03 Feb 2006, 17:13
Kot nalašč "spurius" kabelske televizije, kje drugje kot na 145.990 MHz .
:cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry: :cry:
OdgovorNapisal/-a S56CT » 03 Feb 2006, 18:13
Ravno tako pri meni Adi. Ko sem nastavil frekvenco sem že mislil, da se nekaj dogaja. :D Seveda se je, samo ne tisto kar sem hotel ampak 7 s enot nekega tujega programa na KATV Sevnica.
73 in več sreče prihodnjič de Tilen
OdgovorNapisal/-a s56al » 03 Feb 2006, 18:25
"Moj" kablar ima na srečo slabšo opremo in mu pozimi frekvenca zleze na 145.750 :). Poleti pa se dvigne in mi veselo moti sprejem RV63 (145.787) repetitorja na Kaninu (oni, ki je včasih pokrival celo Primorsko, pol notranjske in pol Istre, ko je še delal :).
OdgovorNapisal/-a s57ezb » 03 Feb 2006, 18:31
Prihodnjic bo isto;pri meni je ze deset let,pa ne samo na omenjeni frekvenci.
73 :evil: :evil: :evil:
s57ezb
Pridružen: 25 Okt 2001, 02:00
Kraj: Sežana,JN65WQ
OdgovorNapisal/-a s51fu » 03 Feb 2006, 23:24
s55m napisal/-a:Kot nalašč "spurius" kabelske televizije, kje drugje kot na 145.990 MHz .
Zivjo,
ali lahko ugotovis, ce ti CATV motilni signal
pride po kablu, ali pa morda po zraku?
gl, DD+
s51fu
Prispevkov: 205
Pridružen: 19 Maj 2001, 02:00
Kraj: LJ
OdgovorNapisal/-a s57ezb » 04 Feb 2006, 00:45
Vsi CATV motilni signali pridejo po zraku,Hi!V mojem primeru ne seva njihov kabel,saj ga lahko sledim z anteno (od strehe do strehe), marvec je signal najvecji ,ko je antena obrnjena v bliznjo hiso.Verjetno seva od kaksnega uporabnika,ali imajo kabelasi spacano razdelilno skatlo..
s57ezb
Kraj: Sežana,JN65WQ
OdgovorNapisal/-a s55m » 04 Feb 2006, 13:35
Danilo, ni iz kabla, ampak je tako, kot je napisal Božo. :o
OdgovorNapisal/-a s51fu » 04 Feb 2006, 15:04
Adi, moram vprasati se drugace:
Ali imas ti kabel pripeljan v tvoje stanovanje?
gl, DD+
s51fu
Prispevkov: 205
Kraj: LJ
OdgovorNapisal/-a S57NML » 04 Feb 2006, 19:05
S tem nenavadnim satelitom verjetno ne bo nič, NASA poroča da naj bi baterijske celice poškodovala prenizka temperatura. :cry:
S57NML
Prispevkov: 140
Pridružen: 27 Maj 2001, 02:00
Kraj: Lasko
OdgovorNapisal/-a s55m » 04 Feb 2006, 19:51
Imam Danilo, pa vsi sosedje tudi :). Dipola za 80m ne morem obračati, da bi videl, s katere strani motnja prihaja :)
OdgovorNapisal/-a s51fu » 04 Feb 2006, 19:59
tks Adi ....
ali se upas s 1-sekundnim kratkim stikom na kablu
preveriti ce motnja na tvoji postaji izgine,
ali pa vsaj mocno pocepne?
Upam, da to sistemu ne bo skodilo .... hmmm
gl, DD+
s51fu
Prispevkov: 205
Kraj: LJ
OdgovorNapisal/-a s55m » 04 Feb 2006, 20:43
Danilo, prav nič se ne spremeni. :(
detalji
OdgovorNapisal/-a s51fu » 04 Feb 2006, 21:12
Problem je kar kompleksen,
pa je tako na daljavo tezko pricakovati,
da bo resljiv kar tako z enim samim
stavkom ali dvema .....
- Ali si poslusal na frekvenci 145.990 MHz
ter seveda s pravilno 2m anteno,
obrnjeno v smeri pricakovanega signala?
- Zdi se mi, da je nekje bil omenjen
fiksni 80m dipol?
oh, jaaaa ...
DD+
s51fu
Prispevkov: 205
Kraj: LJ
Vrni se na Sateliti
