Galileo
OdgovorObjavljeno: 07 Nov 2005, 21:21
Napisal/-a S57NML
Evropska vesoljska agencija že napoveduje izstrelitev prvega satelita za projekt Galilelo, ki bo predstavljal evropski GPS, že za naslednji mesec.
Pa še nekaj, kar se tiče našega L banda, če so informacije točne?
http://www.southgatearc.org/articles/galileo2.htm
lp Andrej
OdgovorObjavljeno: 29 Dec 2005, 19:08
Napisal/-a S57NML
Prvi satelit je že bil izstreljen včeraj...
____________________________________________________________
The first Galileo demonstrator is in orbit, marking the very first step to full operability of Europe's new global navigation satellite system, under a partnership between ESA and the European Commission (EC).
Giove A, the first Galileo in-orbit validation element, was launched today from Baikonur, Kazakhstan, atop a Soyuz-Fregat vehicle operated by Starsem. Following a textbook lift-off at 05:19 UTC (06:19 CET), the Fregat upper stage performed a series of manoeuvres to reach a circular orbit at an altitude of 23 258 km, inclined at 56 degrees to the Equator, before safely deploying the satellite at 09:01:39 UTC (10:01:39 CET).
"Years of fruitful cooperation between ESA and the EC have now provided a new facility in space for improving the life of European citizens on Earth," said ESA Director General Jean Jacques Dordain congratulating ESA and industrial teams on the successful launch.
This 600 kg satellite, built by Surrey Satellite Technology Ltd (SSTL) of Guildford, in the UK, has a threefold mission. First, it will secure use of the frequencies allocated by the International Telecommunications Union (ITU) for the Galileo system.
Second, it will demonstrate critical technologies for the navigation payload of future operational Galileo satellites. Third, it will characterise the radiation environment of the orbits planned for the Galileo constellation.
Formerly known as GSTB-V2/A (Galileo System Test Bed Version 2), Giove A carries two redundant, small-size rubidium atomic clocks, each with a stability of 10 nanoseconds per day, and two signal generation units, one able to generate a simple Galileo signal and the other, more representative Galileo signals.
These two signals will be broadcast through an L-band phased-array antenna designed to cover all of the visible Earth under the satellite. Two instruments will monitor the types of radiation to which the satellite is exposed during its two year mission.
The satellite is under the control of SSTL's own ground station. All systems are performing well, the solar arrays are deployed and in-orbit checkout of the satellite has begun. Once the payload is activated, the Galileo signals broadcast by Giove A will be carefully analysed by ground stations to make sure they satisfy the criteria of the ITU filings.
73 de Andrej S57NML HNY 2006
