Nov satelit <AMSAT-ECHO >
Moderator: S57NML
OdgovorNapisal/-a s56wor » 28 Jul 2004, 16:56
Pozdravljeni!!!
Tisti, ki se ukvarjate s sateliti vas bo gotovo zanimalo naslednje...
Tole je prepis iz programa satscape:
AMSAT-ECHO
NOTES :Launched June 2004 from Baikonur Cosmodrome in Kazakhstan - Among other capabilities, the 10-inch-square microsat--equipped with a transmitter capable of up to 7 W output--will allow voice communication using handheld FM transceivers. Echo will feature V/U, L/S and HF/U operational configurations, with V/S, L/U and HF/S also possible. FM voice and various digital modes--including PSK31 on a 10-meter SSB uplink--also will be available.
Downlink:435.150
DNLINK:435.225
UPLINK:145.920
UPLINK:145.860
Upam da ne zamujam preveč in da vam bo informacija prišla prav.
L.P.
S56WOR
s56wor
Prispevkov: 16
Pridružen: 28 Feb 2003, 20:04
Kraj: Trbovlje - City
OdgovorNapisal/-a s56al » 29 Jul 2004, 07:53
Več podrobnosti na:
http://www.amsat.org/amsat-new/news/
http://www.amsat.org/amsat-new/echo/
Če prav razumem, uporablja FM repetitor na vhodu tonski skvelč (67Hz).
AMSAT 'Echo' Satellite to Open for FM Voice Trial Run
OdgovorNapisal/-a S50DX » 30 Jul 2004, 07:01
from W1AW Bulletin via the ARRL
Website: http://www.arrl.org/ on July 29, 2004
AMSAT 'Echo' Satellite to Open for FM Voice Trial Run:
ZCZC AS11
QST de W1AW
Space Bulletin 011 ARLS011
>From ARRL Headquarters
Newington, CT July 29, 2004
To all radio amateurs
SB SPACE ARL ARLS011
ARLS011 AMSAT "Echo" Satellite to Open for FM Voice Trial Run
AMSAT-NA's new "Echo" satellite (AO-51) will be turned on for general use in FM repeat mode Friday, July 30, at about 0215z, for a trial period of about three weeks. During that time, command stations on Earth will monitor AO-51's power budget and adjust the UHF Transmitter B (TX B) power as needed for good battery management. They'll also be watching the AMSAT Bulletin Board e-mail reflector, amsat-bb@amsat.org, for reports of how Echo is working.
"We are most interested in hearing about how well Echo hears you and how well you hear it," said the Echo Command Team--Jim White, WD0E, and Mike Kingery, KE4AZN--in an AMSAT bulletin. The digital transponder and the store-and-forward BBS, are not yet open for general use.
Initially, the AO-51 downlink transmitter will be running at about 1 W. At that power level, AMSAT says, Earth stations will need a small directional antenna to hear it. If onboard power permits, ground controllers will slowly increase the transmitter's output during the trial period.
The Echo FM voice uplink frequency is 145.920 MHz, and the downlink is 435.300 MHz. The downlink transmitter will come on when it hears an uplink signal with a 67 Hz CTCSS (PL) tone for about 1 second, and it will stay on for 10 seconds after that signal goes away. "This operation is just like a terrestrial FM repeater with a 1 second 'kerchunk' filter and a 10 second hang time," AMSAT noted. Transmitter A (TX A), now sending telemetry, generally will continue to operate on 435.150 MHz.
AMSAT points out that Echo, which launched June 29, is still "wobbling a great deal," so the downlink polarization sense will vary.
The Echo Command Team says it expects Echo will be heavily used during the first few days of the trial period. "Many stations will be trying to make a contact through Echo," they said. "It is good amateur practice and common courtesy to let everyone have a chance. Echo will hear you as well as or better than any previous amateur FM repeater satellite."
There's more information on the AMSAT Web site at, http://www.amsat.org.
NNNN
/EX
Source: W1AW Bulletin via the ARRL
Prispevkov: 468
Pridružen: 23 Apr 2003, 14:46
OdgovorNapisal/-a s56al » 05 Avg 2004, 10:39
Kateri program uporabljate za izračun poti satelitov? Winorbit 3.6 se na mojem PCju ne pusti zagnati :(.
OdgovorNapisal/-a S50DX » 05 Avg 2004, 12:03
Si že probal Satscape?
Prispevkov: 468
OdgovorNapisal/-a s56al » 05 Avg 2004, 13:19
Ta mi pa dela, hvala za info. Nekako sem uspel vnesti koordinate QTHja, vendar mi zemljepisno dolžino vedno zaokroža na cele stopninje, v mojem primeru 14, tudi če vnesem recimo 13.30'. Morda veš kaj je na tem? Saj ne, da bi zaradi tega bil izračun neuporaben, samo zanima me, zakaj.
In da se ne bom preveč mučil z navodili, ti bom hvaležen za namig, kje se v program vnese nov satelit in njegove Keplerjeve elemente. Ostalo sem nekako pogruntal, se mi zdi.
OdgovorNapisal/-a s56al » 05 Avg 2004, 13:41
OK, že pogruntal. Danes zvečer ob 22.00 14-minutni prelet echota, pa še viden naj bi bil :). Sicer preleti tudi ob 20.24 in 23.39 (trajanje 9 in 13 minut).
OdgovorNapisal/-a s56oa » 05 Avg 2004, 21:36
s56al napisal/-a:Ta mi pa dela, hvala za info. Nekako sem uspel vnesti koordinate QTHja, vendar mi zemljepisno dolžino vedno zaokroža na cele stopninje, v mojem primeru 14, tudi če vnesem recimo 13.30'. Morda veš kaj je na tem? Saj ne, da bi zaradi tega bil izračun neuporaben, samo zanima me, zakaj.
Imam enak problem glede te nastavitve.
Mislim, da je to bug, ali pa morbit feature. 8)
73 de S56IUA - Ognjen
Pridružen: 23 Maj 2001, 02:00
OdgovorNapisal/-a S50DX » 05 Avg 2004, 22:49
Hecno... :o
Do sedanj nisem posebej polagal pozornosti na tole....
Men da avtomatsko na 15°, ko mu vpišem 14° in 57''.
Kaj pa veš... Čudna so pota gospodova... :lol: :lol:
Bye
A. 8)
Prispevkov: 468
OdgovorNapisal/-a s55z » 06 Avg 2004, 07:55
Sem Satscape včeraj tudi jaz namontiral in moram reči, da mi je zelo všeč.
Edino, ko sem hotel updatat Database je zadeva izjavila, da je morda server zaseden. Je to kakšna napaka ali je server res zaseden?
OdgovorNapisal/-a s57x » 06 Avg 2004, 09:54
Imam verzijo 1.88, danes dopoldne ni težav z "nalaganjem" novih elementov. Tudi geografija dela BP. Ponovno sem potegnildol koordinate s pomočjo Interaktivnega naravovarstvenega atlasa (odličen pripomoček za določanje UL!), SatScape prebavi st., min., le pri sekundah ima samo tri mesta. Pri meni je tako napaka 7 stotink sekunde pri dolžini, raketo bi verjetno tako ali tako "dobili" sosedje, za satelite pa bo OK.
Na začetni strani pa program prikazuje koordinate v decimalni obliki!
73 Jurij, s57x
s57x
Prispevkov: 381
Pridružen: 02 Feb 2004, 00:24
OdgovorNapisal/-a s55z » 06 Avg 2004, 11:14
Hmmm. Namestil sem verzijo 2.01 Pro, ki sem jo včeraj snel z njihove spletne strani.
Še nekaj. Je AO10 res tako oddaljen od Zemlje (po 3D sliki sodeč), da pokriva kar polovico oble, ali je to kakšna napaka v računanju? Viden je pa komaj dobro uro (po podatkih v tabeli desno).
OdgovorNapisal/-a s56al » 06 Avg 2004, 12:01
s56iua napisal/-a:
s56al napisal/-a:... uspel vnesti koordinate QTHja, vendar mi zemljepisno dolžino vedno zaokroža na cele stopninje, v mojem primeru 14, tudi če vnesem recimo 13.30'...
Pomaga, če namesto 13:33 (E) vpišem 346:27 in odkljukam "west". Potem se koordinate shranijo do minute natančno. Druga možnost je ročni popravek v datoteki "location.dat". Mislim pa, da na izračun to bistveno ne vpliva, vsaj ne pri smernosti anten za 2m in 70cm, kot nas jih ima večina :).
Vrni se na Sateliti
